Question about Gateway FPD1975W 19" LCD Monitor
Gateway lcd monitor goes off and on!
Monitor cycles between no signal, vga, and rgb message/icon on screen between going black. Putting the tour button on stopped it, for the duration. then i was unable to use the power button to power off. Help, please!
  • john Feb 16, 2012
    the button still moves, or seems to move, as it should. How would I go about checking for damage to the button-What should I be looking for?
    Scholar:
  • 51 Answers
First, check to make sure the input selection switch isn't stuck, after unplugging the monitor power cable. It sometimes can get stuck, or just become damaged.
If this isn't it, maybe it's time for a new monitor.
Posted on Feb 14, 2012
2 Suggested Answers
  • 382 Answers
SOURCE: Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Posted on Jul 09, 2010
The monitor won't come on it shows RGB no signal
Are you using the correct cord (HDMI, VGA, etc.)?
Mar 07, 2014 | Gateway HD2201 22" LCD Monitor
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
"No Input" followed by R G B with their respective colors message
Your monitor is set to the RGB input which is the 3 cable connection that alot of older HDTV's use. There should be a button on the monitor to switch inputs so if you are using a DVI connection make sure it is set to DVI input; same if you are using VGA. Once the proper input is set your monitor screen should come on. Hope this helps.
Jul 02, 2009 | Gateway FPD2275W LCD Monitor
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Gateway LCD powers on but has no picture
To solve your problem you can go to any rad shack or electronics store and pick up a DVI-AVG adapter. The're about $14.00.
Jan 16, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
128 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
