Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
V chip password reset
I recently purchased a t.v. and it was an off the shelf item and someone had set the v chip password. I've tried several passwords starting with the obvious and just making things up. The store I bought it from can't help me and the manufacturer will not help me because it was an open box item. Does anyone know a universal reset code that I can use to fix this problem? I would greatly appreciate anyone's advice on this issue. Thanks, Michelle
2 Suggested Answers
milkburp
  • 416 Answers
SOURCE: NEED TO UNBLOCK INSIGNIA TV - DON'T HAVE PASSWORD
The default password for this model is 1234. If you have never changed the password, it should still be the same. I hope this was helpful, best wishes.
Posted on Apr 18, 2010
I already have several items--phone,tablet, IPad, Kindle--hooked to router we purchased in March. Now I cannot connect new products.
They do get changed sometimes, you have have to get into the router or call the manufacturer of the product you are trying to log into, to reconfigure it.
Dec 12, 2015 | Samsung Tablets & eReaders
Hi i've forgotten the password i set for my router about 18 months ago, so i can access wifi on my ipod touch, i've tried to reset and restore to factory settings using the button on the back,...
Since you reset the router, the username and password were set back to its default values as well. For Netgear, the username and password is: Username = admin Password = password
Aug 29, 2011 | NetGear WNR2000 Wireless Router
I have a samsung who forgot pasword, how to reset the pasword
There's good news and bad news. The good news is that you might well have forgotten that the default password on the Samsung phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.
First, here's what Samsung says about working with passwords on the Security
Use this menu to protect the phone against unauthorized use by managing the several access codes of your phone and SIM card.
Note: If you enter an incorrect PIN/PIN 2 three times in succession, the SIM card is blocked. To unblock it you need to enter your PUK/PUK2 (Personal Unblocking Key). The codes are supplied by your network operator.
PIN check
The 4-to-8-digit PIN (personal identification number) protects your SIM card against unauthorised use. When this feature is enabled, the phone requires your PIN each time it is switched on.
Change PIN
Use this menu to change your PIN. The PIN Check feature must be enabled to use this feature.
Phone Lock
The Phone Lock feature locks the phone from unauthorised use.
When this feature is enabled, you must enter a 4- to 8-digit phone password each time the phone is switched on.
The password is preset to 00000000. To change the password, use the Change Password menu.
Change Password
Use this menu to change your phone password. The password is preset to 00000000.
Privacy
Use this menu to lock your media contents, including MMS messages, emails, images, videos, music files and sounds:
1. Press [OK/i] to check the item(s) to lock.
2. Press Save to lock the marked items.
3. Enter the phone password and press OK.
To access a locked item, you need to enter the phone password.
If that doesn't help you, as I said, you'll need to take your phone to the local service center and ask them for help. Just a tip: bring some sort of proof of purchase or ownership so they can differentiate between you losing your password and someone else showing up with a stolen telephone.
Jul 13, 2011 | Cell Phones
Can anybody tell me the location and/or board identifier of the bios chip on the motherboard for this model. I'm trying to clear out a password (the start-up kind) for a friend of mine, but I've...
some motherboards do have a pin/plug which can remove passworcs i would need to name and model number of the board to find the specifications Power off the computer and make sure that it is unplugged
Open up your computer case. You need physical access to the motherboard to complete this procedure
Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery
CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. (See Warnings)
Set the battery back into place and power on the computer
The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine.
You will notice that the BIOS password has been cleared and you can boot without it. You may reset the BIOS password to something else by going into the BIOS configuration and setting a new User Password (The Supervisor Password controls access to the BIOS, NOT the computer!)
Hope this helps
Jun 25, 2011 | Computers & Internet
Hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Jul 28, 2009 | HP Computers & Internet
IBM Thinkpad T-30 2366 QU-5 Padlock appears on scree. I cannot do anything. How is this unlocked? Please help.
You have a Power on Password. The correct password has to be entered before the laptop will bootup. The password is set to prevent unauthorized access to the laptop.
Did you purchase this laptop from someone? If so get the password from them. There is no backdoor password and the password is stored on an EEPROM chip so removing the BIOS battery will not reset the BIOS and remove the password.
Jul 06, 2009 | IBM ThinkPad T21 Notebook
My password is "wrong' whenever I try to connect on my laptop
That's firmware problem on your router. Try to download the latest firmware for you router from www.linksys.com/download then load the latest firmware. After successfully updated the firmware, you need to hard reset the router by pressing the reset button for 20 seconds then unplug the power for 10 seconds and plug it back in. You will need to reconfigure the wireless settings.
Apr 15, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Forgot V chip password on Insignia IS-TVDVD20A
i have an insignia hdtv and the manual says if you forgot the password, enter in 3448 in the password box to reset, it might be the same for yours, good luck
Jan 04, 2009 | Insignia IS 20" TV040919 TV
I need to overide a bios password
due to fixyas terms and conditions, this information can not and should not be posted on the forums.
this is due to obvious legalities, of who the laptop actually belongs to ?
The person in charge or purchaser of the item, should have any relevant information to unlock any security passwords. Newer style laptops actually have security chips on board, which can only be unlocked or passwords provided by the legitimate owner of the item, or by contacting the manufacturer for an unlock password. i,d suggest that you contact your client for this information.
Thankyou for using fixya.
mike @ compurepair.
Nov 17, 2008 | Computers & Internet
Ilo 42" tv - v-chip code?
Try these codes 8202 or 8205. Hope this help.
Jul 17, 2007 | iLO 3200 32 in. LCD Television
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
