Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Hard drive disappears on it's on
  • 1 more comment
  • Rocco A Colantonio Feb 14, 2012
    I don't understand your question.
  • Brian Sullivan
    Brian Sullivan Feb 14, 2012
    you might have to reword/rephrase your problem
  • andrewchrw
    andrewchrw Feb 15, 2012
    what i mean is that my hard drive hangs every time i try to install window on it
  • Seagate Master
  • 27,725 Answers
Maintainence check
test all leads that attach to your hard drive including electrical extensions SATA/IDE
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
also clean your
computer all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
hope this helps you
Posted on Feb 15, 2012
"the parameter is not correct" msg re WD My Book, unable to access
Try plugging it into a different computer to see what it does. Sometimes a computer's operating system will recognize an external drive differently if it has only a slight problem, whereas another computer's configuration may treat the problem differently. Some external hardrive software can get jumbled by the programs of a computer or sometimes even their own software programs can cause slight problems. It sounds like a software problem with bugs that can be ironed out. Also some computers will change the drive name to fit into the order of drives it recognizes. Good luck!
Jun 01, 2013 | Western Digital WD My Book Essential...
Samsung Story Station 2TB External HD has lost all my files ?!?
You need to get the disk to a data recovery expert. anything else might make it worse.
Nov 14, 2017 | Samsung STORy Station 30 2TB USB 30 Dark...
Honda crv 2003 - squeaking / squealing nosie from passenger side that disappears when braking or turning hard
If only the pads were changed then you can't expect much
Proper brake service requires hours of rust removal,lubing
certain places & parts,new or machined rotor,fluid flush and
much more.
No reason at all for brakes to squeak except poor & sloppy
work
99% of that comes from the pros
Those who work on there own cars eventually learn the
proper way to do things & resolve problems
I don't know your situation or where the work was done or
by whom
You could have rusted & frozen caliper pistons from never
changing brake fluid every 2 years or bad flex hose holding
pressure on pads.
Nov 13, 2012 | Cars & Trucks
Unpartition hard drive
This can be done in Disk Management by deleting partitions. Win 7 partition expansion aka dynamic drive properties. Or just right click on drive and format.
Aug 26, 2012 | Computers & Internet
I have a Lenovo H430 Desktop & i Got a Seagate 3Tb Internal Hard Drive & i can't get the computer to detect the hard drive & everything i have tried & even Seagate tried nothing wo
hi..there...
why your lenovo H430 Desktop cannot detect your internal Hard Drive Seagate 3 TB ..because your Lenovo only support maximum 2TB Internal Hard Drive..
so the best thing to solve your problem is replace your hard drive and use only maximum 2 TB for your internal hard drive..
that's will make your lenovo works again
Aug 24, 2012 | Computers & Internet
How to repair and recover WD5000AAKS hard drive
The problem may be there in your hard drive, try the hard drive with another computer and if the problem persists, go to the nearest Service Center of the Manufacturer.
If the problem is solved on another computer, try repairing your OS first.
Hope this helps, Mrityunjay.
Jun 20, 2012 | Western Digital Caviar 500 GB
HARDDISK SECURITY PASSWORD FOR WDC WD3200BPVT-22ZES
Saw on a forum that this could be the default password.. wdcwdcwdcwdcwdcwdcwdcwdcwdcwdcwd
-put DOS on a floppy disk
-add atapwd.exe to the disk
-turn off the computer & connect your Western Digital hard drive.
-turn on the computer and inset floppy
-type atapwd.exe after A:\
-when the menu loads click on your harddrive
- >Prepare Erase
- >Erase
-enter the password " wdcwdcwdcwdcwdcwdcwdcwdcwdcwdcwd "
-It should come back with an error, press enter and the hard drive name will disappear from the list
-DO NOT RESTART-...Your harddrive is being formatted.
-Let it sit at that screen for 30mins
-Afterwards, press the F5 key(refresh) and the hard drive should reappear on the list
-restart...and it'll be unlocked.
I don't know if that will help your problem but I hope it helps someone. :thumbsup:
THIS WILL DESTROY DATA ON THE HARD DRIVE
Jun 24, 2011 | Acer Aspire 5315 Notebook
I continually get the pop up asking whether I want to scan & fix the verbatim HD after I have done it a number of times
Hi
You just installed in your computer a USB virus scanner sofrware. Just uninstall this software and this message will disappear every time you plug external HDD.
Regards
Apr 05, 2011 | Verbatim (R) Wallet Drive(TM) USB Portable...
Can't open external hard drive.
Hi, not sure about this one, you could try looking at the external hard drive, it should have small connoctors at rear, near power cables, the conectors should be configured for a "slave", if its wrong, computer is trying to look for opperating system, and cant, pannicks, & sulks.
The external drive should now come up, d: or e: or f: or h: or whatever!
Hope this helps.
Dec 31, 2017 | SimpleTech SimpleDrive Pininfarina 320GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
