Question about Exercise & Fitness
Speed problem when i set machine on any speed it shows the same speed but works more than that speed
    Top Expert:
  • 12,223 Answers
Dear Sir:
Thank you by you contact.
I would appreciate that you put to work inmediately your software calibration.
This software has the particularity to diagnose and troubleshooting the equipment and fix it !
You can find below the Hood motor and follow the intructions, or in your user guide manual.
Sincerely. God bless you.
ernesto a cuadra
managua, nicaragua. c.a
Posted on Feb 14, 2012
I have a fibre connection. When I do a speed test at speedtest.net it shows 20m whereas on my both my lap tops the speed is 37m. Upload speed is the same on all3 at about 1.7m. When I test the quality of...
Verizon Fios users can run a tuning program on EACH machine that sets up the connection for best speed and performance. It can be found here:
http://www2.verizon.net/help/fios_settings/optimizer/
If this doesn't apply, please provide the name of your broadband provider.
Sep 06, 2013 | Dell Inspiron Zino Hd (AMD Athlon II X2...
Hi, i have KEB inverter type F4C on my CNC machine... it shows the message L5 (or LS i am not sure about the symbol). The machine showing motor problem and inerter problem. Please advise me on m y ema
LS means Low Speed. The inverter is enabled and is waiting for a command.
Check your speed and direction signals at the inverter to verify if they are active.
Nov 16, 2011 | Inverter KEB COMBIVERT F5
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Washer does not work at regular speed, it works on other setting
Since the machine works in two of the three speeds the problem points to either the timer or the switch that sets the speed.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Go to the control panel category and see their diagram and list of switches and parts.
These aren't that difficult to replace but they aren't inexpensive.
Sep 14, 2009 | Kenmore 15864/15862 Top Load Washer
Washer's fast agitation speed is the only speed working
I opened up the control panel of the washer to check the speed control switch and found that one of the wire connectors on the switch had pulled loose from its terminal. I reattached the connector and the machine is working fine again.
Mar 19, 2009 | Kenmore 20722
Speed dial number
Hi,Press your user button(the dataregistration button) if it show dataregistration on the screen press the arrow key once and it will show (tellefoneregistration),press ok and enter the numbers in one touch dails.
Sep 30, 2008 | Canon FAXPHONE L80 Laser
Bios reports incorrect memory speed
setup new bios and remove your old battrey ..........
Jan 24, 2008 | EPoX EP-MF570 SLI Motherboard
Exercise & Fitness Logo
22 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
