No resulotion on screen when laptop is booted up
Bought it off car boot it all powers up but no picture is displayed on the screen i think a part of it is missing
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps you
Posted on Feb 14, 2012
mewms_14904
  • 1027 Answers
SOURCE: new laptop
Open the hard drive bay and make sure the hard drive is properly seated. close bay
reboot and enter bios to see if hard drive is detected in bios, if the hard drive is detected and still will not boot use recovery console to recover the OS.<ALT><F10>
If the bios does not recognize tthe hard drive, replace hard drive.
Posted on May 08, 2008
  • 199 Answers
SOURCE: won't boot-up
dear,your operating system has been crashed.
this problem is occured when windows install another drive (beside C)and user accidently formate the hard drive in which you install.
or another method ...........
sometimes boot order has been changed and problem occured.
once you check the boot order from motherboard setting.
you set the BOOT order as:
first boot from hard disk
second boot from floppy
third boot from cd rom.
i think you solve this problem easily.
Posted on Apr 11, 2009
leecom72
  • 4806 Answers
SOURCE: i just bought a used ibm think pad laptop
Hi there.
If you have just bought the laptop chances are the operating has been removed to you cannot see any data that used to be on it, you need to go and purchase a windows OS that the laptop was built for (i'm guessing XP) and re-install the operating system again.
Good luck and thanks for using FixYa!!
Posted on Apr 21, 2009
Geekman
  • 32281 Answers
SOURCE: diplay will not boot up toshiba satellite laptop
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 08, 2009
gabysrivera
  • 8 Answers
SOURCE: The laptop appears to boot but no display even on ext monitor
Check the memory bank "Ram"... If you don't know how to change it, I recommend you go to a professional that will test it for you...
Posted on Jul 21, 2009
Restoring my laptop back to factory settings
Many laptop vendors put a special restore partition on the disk. At boot up, you should see a brief black and white message that says hit F? for boot sequence. At that next screen will be an option to restore you computer.
Be aware, you are going to loose anything you have done since you bought the computer, think data, settings, pictures, etc.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Computers & Internet
I turned on my m-675 yesterday and got the gateway green and black screen that just continued to stay there. After 5 minutes I used the control/alt/delete buttons to reboot my computer. Now, my computer...
From the information, that you used control/alt/delete to re-boot, I am assuming that you sensed that the computer finished the booting process. Meaning the tell tale sound (music) of windows booting was there, the hard disk whirling (blinking LED) for a certain period and stopping etc. If that is the case, (meaning you think your computer is capable of booting) probably you have a display failure. If you have a VGA cable connect that cable to the VGA connector (0n your laptop) and connect the other end to Desktop screen (monitor) or a TV screen with a VGA input. Probably you will see a display right away. If not press the Fn key and the key which changes the screen from laptop to external screen. This key will be marked either as CRT/LCD or with a picture( a square with two lines on either side of the square). If you get a display there, you may need to get a technician to change the screen.
Feb 11, 2010 | Gateway M675 Notebook
Compaq f756NR laptop won't boot.
I think this is a problem with the laptop's LCD display. To verify this connect the laptop to an external display and see if it resolves the issue. If it does then its confirmed that its a display related issue. Since the issue has appeared suddenly I dont think its a serious problem. May be just loose/disconnected connectors. Should be a 10 minute job for a qualified technician.
If the external display too doesn't come on then its an issue with the graphics card and you may need to replace it.
Oct 24, 2009 | HP Compaq Presario F756NR Notebook
Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
My Toshiba Satellite A215-S7437 will not boot. Unfortunately by "will not boot" I also mean will not boot to bios, in addition to not booting normally. Essentially, when the power button is pressed, the...
you should see the post screen if the monitor is working. try hte fn and the monitor or display key. some laptops toggle the display this way. another possibility is the lid switch that shuts off the display when you close the lid. and it could be heat damage.
Jul 20, 2009 | Toshiba Satellite A215-S4747 Notebook
I would like to reset my computer to the day I bought it.
OK, you need to locate to system CDs that came with your laptop. One of them will be disc 1 or operating system or Windows CD. Insert into the CD ROM drive. Power up laptop and when "Press any key to boot CD.." is displayed, press any key on the keyboard. If this message doesn't display, then the CD will boot and just follow the on-screen messages to install your OS. If your laptop doesn't boot the CD, then you need to go into your BIOS and set the CD-ROM drive as the 1st boot device. Follow on-screen messages during boot-up to enter your BIOS or try pressing the DEL or F1 or F2 or F12 key while powering up your computer. If you do not have the system CDs, then you need to call Toshiba and order them.
Apr 25, 2009 | Toshiba Satellite A105-S4254 Notebook
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Black screen will not boot up
go for the bootable cd and after install new o/s in the laptops
Jun 04, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
