NEC NFL-1065 washing machine won't drain or spin
My NEC NFL-1065 washing machine has decided to play up right on cue after warranty. When it gets to the rinse/spin cycle it freezes. Last night it had the Error Code  0E which means the 'The washer will not drain'. But I reset the cycle and now it just stops when it gets to the spin/drain stage (there is plenty of water in there) and the clock freezes while there is a weird electrical noise like the pump can't get started (sounds like a slight vibration of a plastic part too). I cleaned the pump filter and have drained it a couple of times but still no joy. I even sucked on the outlet drain hose but no water came through - I could hear bubbles in the machine when I blew into it. I don't think it's a blockage or mechanical problem but electrical. I hope it doesn't need a new motherboard or something... Any ideas?
  • 3 more comments
  • Anonymous Nov 08, 2008
    Same problem with a frigidaire... seems intermittent though. Ideas ??
  • glennarcher Jan 03, 2009
    Same problem with my NEC washer.... bloody annoying... any help please!
  • fuk-ya Jan 13, 2009
    yes i have the same Problem, but the best i could come up with was when it trys to drain just take out the filter plug & it will go to the next cycle.
    oh by the way you do it 2 times per wash & on the 2nd time you leave it out. I did this 4 times or so & now it just work fine by it's self, hope this helps. =)
  • DaveP008 Mar 05, 2009
    I have the same problem, its driving me nuts... help please...
  • gabby2553 Apr 25, 2009
    My machine is also an NEC NL-1065 and I get the code "E8" and it won't do anything. Any ideas on what it could be?
    Gabi
I had the same problem , I replaced the pump havent had the problem again. Then the heater element blew, (kept triping the house fuse) replaced that, then the door would'nt lock everytime, now it will fill up then give a code "E8" I think it's the mother board
Posted on Mar 07, 2009
  • timyen Nov 10, 2010
    Im having the same problem. I pulled out the drain pump and the plastic head on it has come off the metal spindle. $77 to replace it seems. Looking for a cheaper option.
Start button won't work on NEC nfl-265 washing machine
My Samsung washing Maching DC68-20425B driving belt ( elastic )has been damaged, kindly give me it's code number , please
Thanks a lot
Sep 25, 2013 | Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
Washer won't drain. Cleaned hoses and pump. Motor gets hot and just buzzes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | General Electric WBVH5100HWW Front Load...
Washing machine won't rinse and the water won't drain out.
heatman101
Sep 04, 2011 | Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
heatman101
Aug 28, 2011 | Washing Machines
Fills with water, won't spin water out, get F50 message
heatman101
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
How to open door on front loader when unbalanced. Nec Nfl 1065.
unplug the unit for a couple of minutes and try it
Jul 26, 2009 | Washing Machines
The water wont drain out off the washing machine there is an error code UE is flashing and it wont finish spinning i have taken off the drain pipe and its not blocked and i have emptied the water via the...
YES ! there is something else , check the little MOTOR that is attached to the drain hose , take it out , take it apart and check if there s some stuff blocking the motor inside ,hopefully this will take care of the problem .
Apr 17, 2008 | Washing Machines
Washing Machines Logo
1,244 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
