Question about Intel D865PERL Motherboard
Troubleshoot My pc does not work up, but sometimes it will on i try to check the CMOS battery replace a new one and reset. It works, i set the date , works ok, but after shutting down and turning ON again the Error coming again, it says :CMOS ERROR -.. After i check and replace the new CMOS battery the pc not working anymore( motherboard is Intel Desktop D865PER) Please reply to : hubag_2000@yahoo.co thank you so much
  • doaoto3 Apr 20, 2009
    I have a intel pentium 4 3.0 ghz w/th and1gig kingston ram, seagate 500 gig hd, geforce fx5200 video card with 2 lcd monitors connected.
    My computer overheats to the point of shutdown, I have changed out the memory with other memory I had, doesn't help, I've removed the video card and ram. rebooted to reset anything that may have gotten out of whack. reinstalled the ram, rebooted, shutdown, plugged in the video card, rebooted. still overheats and yes my fans are working plus I added a new one for the tower and bought a new fan for the processor and also bought a new processor. It still overheats!!! I also purchased a new battery first to see if that was the problem and checked for loose connections and neither one helps. Do you think it may be my video card or motherboard?
  • 883 Answers
SOURCE: Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Posted on Jun 24, 2007
rionxz
  • 48 Answers
SOURCE: nedds nedds Intel Desktop Board D101GGC - Motherboard - vga drivernedds Intel Desktop Board D101GGC - Motherboard - vga driver
try this link.. http://www.userdrivers.com/Motherboard/Intel-D101GGC-Desktop-Board/download/
Posted on Sep 24, 2008
SOURCE: Intel 102ggc:The Firmware has detected that Cmos Checksum Error
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Posted on Dec 16, 2008
myjosh007
  • 530 Answers
SOURCE: hi i have a intel D845 PESV motherboard
hi im josh in cebu phils.may i help you? Friend try to read these.ths may help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video
Remember these points when you have a video-related problem:
  • Most display problems are caused by video card/monitor mismatches, bad or outdated display drivers, or improperly connected cables.
  • One good way to determine whether a video problem is card-related or monitor related is to connect a different monitor to your system. If the new monitor works fine, the problem is in your old monitor; if it doesn't, the problem is with your video card.
  • Most video card–related problems will manifest themselves before Windows launches.
  • Most driver-related problems will manifest themselves after Windows launches. good luck.
Posted on Mar 04, 2009
freetek
  • 5568 Answers
SOURCE: sounds was lost
Look for the listing of the sound system on your computer under Device manager and delete it.
Go to Start, then Control Panel, then System folder, then Hardware tab, click on the Device manager, locate Sounds, video and game controller and expand it. Look for a company name such as Realtek, highlight and delete it.
Reboot your system. This should force Windows to reinstall (New Device found) the driver software that is probably corrupt thanks to Windows.
This should restore your sound unless there is a hardware failure (uncommon).    If it doesn't find the sound chip, you will have to replace the motherboard or buy an add-in card. The latter could bring new problems with it though.
You could also try the system Restore routine and back-date the system to a restore point before the music died.
Posted on May 20, 2009
My notebook will not boot properly, and date and time resets.
please use this small secret. Disconnect the power adapter from computer 2) DISconnect the battery from laptop.
3) Press the main button power for 60 seconds exactly. This method discharge any ESD. keeping in the system. and try again, will be work.
However if the problem persist see the flow charts. attached.
Mar 06, 2013 | Computers & Internet
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
When i boot my system iam getting an error Check Date and Time settings and System CMOS Checksum Bad and Default configuration is used. F1 : Resume F2 :- Setup
Hi Good day!! That error maybe cause of your CMOS battery it may be not working, replace your CMOS Battery (2032 3volts), after you replace it with new one, set your date and time setting according in your time zone.
Oct 13, 2010 | Computers & Internet
Came home computer was on black screen and now it won't reboot. When I try to reboot, I get a "cmos checksum error ". Keyboard also isn't working. What could be the problem?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time & Date etc.
Sep 02, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
HELP
Its simple. there is a small cell battery in all motherboards. its usually for BIOS CMOS memory. if the battery drains up the memory in bios just erases. Date and time, bios CMOS settings will be reset after every shutdown or restart. try to replace that battery. Battery is used CR2032 coin cell.
Dec 14, 2009 | ASUS A3H Notebook
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
Bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Oct 23, 2007 | IBM ThinkPad G40 Notebook
Intel D865PERL Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
