Question about LG WM-2077C Front Load Washer
LG front load machine with LE code and no spin
We have this machine for 3 years, the LE code just come on and the machine not spin. We clean all the line trap and drain water as weel. No spin. Thanks
Tuan Tran
  • Anonymous Apr 01, 2014
    LE error code came up on my washing machine & it doesn't seem to be able to spin
    An expert whose answer gotĀ voted for 100 times.
  • 88 Answers
LE is a locked motor error. Not to worry as 95% of the time this is just a bad hall sensor (motor position sensor). It is very easy for a technician to replace and the cost is very small.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Jun 16, 2012 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from or for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
Won't spin LE is on
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
Apr 24, 2011 | LG WM-1832C Front Load Washer
My LG 2277HW gave the LE error and we replaced the entire motor based on a Washing Machine Repair Company's advice. Within the month the machine would not spin the clothes all the way out and eventually...
The LE issue should of been for the followinig, not a motor:
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The ball sensor is out of order/defective.
The OE error means it is not draining. Two diffrent issues.
Are you sure you cleaned out the drain filter on the bottom? Not just drained it. You have to drain it then pull the filter out and clean it.
Mar 01, 2009 | LG WM-2277HW Front Load Washer
LG front washer keeps getting "LE" error. I cleaned out the filter on bottom front left side, but the machine still doesn't spin when it's on. It hand spins when I have the door open, otherwise that's it....
Regarding the LE EEROR CODE.... This code is also caused by having a residue on the sensors in your unit. You have to use a HE liqud detergent.If you use fabric softner use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vineager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE.
The spinning may be a burnt out motor, you may have to get a repairman on that, I can't be sure on that but I hope this helps solve your problem
Mar 23, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Le code and can start but sounds bad (rattles behind drum)
very unlikely it's the motor but could be the bearing is grinding or one of spyder bracket at back of drum has broken off. If you put it into spin with no load and just grinds then bearing is gone. if the drum wobbles and rattles then bracket is broken.LE code may or may not be related. Sometimes just plugging and unplugging the hall sensor at the back will eliminate the problem or just resetting it the way you did it. but if there's a real problem it will come back again.
Aug 24, 2007 | LG WM2688H Front Load Washer
LG WM-2077C Front Load Washer Logo
519 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
