Question about HP Mini 1000 VT series PC Notebook
HP Mini 1000 VT won't turn on, lights flash when plugged in
When I turn on the power switch, the light on the wireless switch flashes once and makes a clicking sound, but the computer won't turn on. If I plug it into the power, all of the indicator lights intermittently flash and it makes a clicking sound. Is it likely to just be the battery? I have tried taking out the battery and putting it back in.
  • 596 Answers
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Posted on Feb 14, 2012
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Computer won't turn on
try removing the battery and see if it runs on mains power, if so you need a new battery. another possibility is that the system has overheated, although you would normally expect it to start up once it has cooled down, unless it has done irrepairable damage!
Mar 08, 2012 | HP Mini 1000 Netbook
Hp netbook won't power up
open the battery & power on
Dec 19, 2011 | HP Mini 1000 Netbook
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
Hp mini 1000 does not seem to recognize my wireless network and the wireless network light will not come on. What do I need to do?
The front of the HP Mini 1000 Netbook has two switches and two small lights. The two switches are for power and wireless. The two lights are for hard drive activity and power. Both the power and Wi-Fi switch are designed exactly the same. They are flat with a little bump where a light is.
Check if the switch is on before trying to reinstall the driver.
Hope this helps!
Apr 13, 2011 | HP Mini 1000 Netbook
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Not powering up. The LED power light is just flashing when the battery is in.when the battery is taken out it remains lighted up but goes out when the power switch is pressed.
Try draining the static of the computer.
Turn off the system
remove the AC Adapter and all 3rd party devices if there is?
Remove the battery
press and hold the power button for 1 minute
then,
plugged back in the AC Adapter and battery
turned on the computer
May 19, 2010 | HP Mini 1140NR Netbook
HP Mini 1000 VT series  PC Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
