Question about Canon VIXIA HV30 DV Camcorder
Canon Vixia HV30 will not be recognized
Hey,
I'm using this vixia camcorder and its worked great, but I cannot get it to be recognized by either a pc or a mac. is there a crucial setting I haven't nailed down?  Thanks so much
  • 5 more comments
  • candlelight Nov 13, 2008
    I have xp2 and my new hv 30 is not seen at all on the usb2 port. I tried to capture in both Vegas 8 and Premiere 4 elements...no luck. And yes, I know how to read and follow the manual. ;-) Help us someone!
  • Kenny610 Dec 01, 2008
    My computer does not recognize my vixia hv30 through a known working fire wire port.
  • Devilcow1 Dec 29, 2008
    hv30 here. Moviemaker doesn't recognize that there is a camera connected via firewire (or USB either)
  • kraazzyj Mar 29, 2009
    Yea I am having the same problem. But my cameras has been recognized maybe 2 or 3 times before. It seems it only recognizes when it wants to. Honestly, and i hope I am wrong, I believe it is about timing when plugging the stuff in. im actually using a dell studio 15 laptop with vista. Im not sure if windows has anything to do with it but it might. If I find something ill hit send it 2 you.
  • arosenzweig May 11, 2010
    Maybe I can help.  What video editing software are you using? On the camcorder's display, does the image of a small IEEE connector show and below it "HDV/DV"?  Are you trying to capture HDV or standard (4:3) DV?  HDV capture is much slower then std DV and you really can't see it in real time on the computer playing from the camera.
    PS: I assume you have tried everything in the manual?
  • Alex Libes May 11, 2010
    Plug in firewire cable, and try playing video on the camcorder. Does it show up in Windows device manager? If so, does video editing software see the camcorder?
  • power_surge_
    power_surge_ Aug 15, 2012
    Im having the same problem. In the past ive been able to connect. I sent it in for repairs because the firewire port was broken. Had that fixed and worked fine. this is the 3rd time connecting and again im having problems. Ive tries two different compputers and still no luck. I connect my other camera and no problem. Ive narrowed my problem down to the cam. Any fixes yet?
Video transfer is only possible through Fire wire/ 1394/DV cable.USB can only sned pics to your PC
Posted on Apr 01, 2009
  • Loretta Rodger
    Loretta Rodger Sep 03, 2013
    we already know this digitallyurz, but the computer doesn't recognize the computer with firewire to usb or hdmi cable. Now what? I have the battery out help
Reset canon vixia hv30
I'm not familiar with this camera but, I would expect there to be an option in the menu to "factory reset" or words to that effect.
Sep 03, 2013 | Canon VIXIA HV30 DV Camcorder
Tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 | Computers & Internet
Tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step1: Install and Launch Doremisoft AVCHD Converter for Mac
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 | Computers & Internet
Macbook pro doesnt recognize my canon vixia hv30
Try a different cable, the one you're using may have got damaged.
Check the firewire driver is installed and running on the Mac.
If the camera came with software, try re-installing it.
Good luck.
Dec 05, 2012 | Canon VIXIA HV30 DV Camcorder
I recorded a MiniDV with a HD camera the Canon HV30 to be specific. When trying to play it back on my Canon zr950 i get an error message. Will my tape only playback on an HD video camera? What do I do?
Canon ZR950 is an older Standard Definition camera that records in DV format, and does not recognize HDV format recorded by HV30.
HV30 can be switched to DV format, which should be playable on ZR950.
Dec 10, 2009 | Canon VIXIA HV30 DV Camcorder
I have a Canon Vixia HV30. My computer is an HP
There are some free ware PC video capturing programs. Be aware, you get what you pay for.
I would try going to Microcenter's or Best Buy's web sites and seeing whats available.
Blessings,
A/V Media Guy
Nov 19, 2009 | Canon VIXIA HV30 DV Camcorder
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
Sep 16, 2009 | Canon VIXIA HV30 DV Camcorder
Canon HV20 or HV30 Service Manual? Does it exist?
Hello, you can find the official service manuals for the canon in the below links, i had bought hv30 and the manual is great
HV30 Service manual:
http://goo.gl/WibRy
HV20 Service manual:
http://goo.gl/4kkHS
and if you need other service manuals you can search for them here
http://ebookswizard.tradebit.com
Hope it helps.
Aug 21, 2009 | Canon VIXIA HV30 DV Camcorder
Need Canon Vixia HV30 driver
If you have windows xp or higher you don't need drivers just an intel based pc, atleast 1 or 2 gigs of memory and try it with the software that came with it...if you dont like that make SURE your version of adobe works with the HDV format....make sure your settings IN the software program are correct...and viola!...MAKE SURE YOU ARE USING A FIREWIRE 4 TO 4 OR 4 TO 6 PIN CABLE no exceptions
May 11, 2009 | Canon VIXIA HV30 DV Camcorder
Canon VIXIA HV30 DV Camcorder Logo
1,967 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
