Question about Kyocera Mita KM-5035 Printer
C7400 error kyocera km 5035 - Kyocera Mita KM-5035 Printer
    Sniper:
  • 76 Answers
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
Posted on Feb 14, 2012
    New Friend:
  • 54 Answers
Posted on Jun 17, 2014
FixinFax
  • 3085 Answers
SOURCE: Kyocera KM-5035 - I try to change the Developer
After replacing developer unit
press
10871087
scroll up to u130
press print button
let machine run till it stops.
clear
u001
press print button
READY
Posted on Jul 11, 2009
  • 66 Answers
SOURCE: 0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Posted on Mar 21, 2009
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
Posted on Dec 07, 2009
shawn38
  • 200 Answers
SOURCE: Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Posted on Feb 19, 2010
Prefab
  • 152 Answers
SOURCE: My Kyocera KM-5035 receive error
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Posted on Feb 05, 2011
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
What does error c7400 singnifies in km 2035
C7400
Image formation unit connector insertion problem.
Absence of the image formation unit is detected.
Jul 26, 2014 | Kyocera Mita KM-2050 Printer
KM 5035 0630 FAULT CODE
Fuser failure , enter service and reset fuser error.
Jul 15, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera 5035 scanner c7400
Image formation unit.
Has the drum been removed from this machine.Its either missing or requires replacing
Sep 19, 2013 | Kyocera Mita KM-5035 Printer
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
Mar 13, 2009 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-5035 Printer Logo
1,155 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
