Question about Toshiba DR4 DVD Recorder
Scrambled picture DVR records fine and sound is fine, but at times picture will begin turning red and scrambles like a scrambled station on TV. Sometimes will clear on its own and sometimes I have to turn off or unplug to clear. Picture will do this whether watching TV through DVR or watching either recorded disk or purchased movie disk. Used lens cleaner disk and did not fix problem. I think problem originated when trying to view a disk that received an error telling me to clean disk or disk was bad. Any suggestions or ideas? DVR only 7 months old.
SOURCE: Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Posted on Aug 23, 2007
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
  • 1694 Answers
SOURCE: picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Posted on Nov 01, 2007
photog1
SOURCE: System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Posted on Dec 03, 2007
  • 82 Answers
SOURCE: movie skips and freezes during play
CD and dvd disc cleaners will not solve the problem, a deeper and delicate cleaning procedure by cleaning the lens manually with an cotton swab is needed...
Although the quality of newer discs is to be discussed.
Posted on Dec 08, 2007
I have the vc500 hooked up and the software installed. I can see the video on the computer screen but when I press record, the computer video looks like it is scrambled. How do I correct this?
Just a wild pitch here; is the video fine after its been recorded or does that play scrambled as well? Make sure your equipment is tightly plugged in. Other than that, all I can say is maybe your dvr is obsolete or your computer is too slow.
Sep 19, 2014 | Diamond Multimedia ( VC500) Video Capture
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Picture keeps getting all scrambled
sounds like a problem with the main board and or av connector cord. contact vizio and let them know you are seeing some red pixelation. some parts on vizios carry lifetime warranties, it has been my experience that this is a covered issue. hope this helps.
Apr 07, 2009 | Vizio 42 in. LCD TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
W2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
Aug 19, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Toshiba DR4 DVD Recorder Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
