Question about InFocus Office Equipment & Supplies
Infocus in760 running very hot
Replaced bulb now getting very hot
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Posted on Dec 09, 2009
  • 74 Answers
SOURCE: infocus in34 bulb replaced now won't light back up
looks like you power supply is defective. My best guess is that this is the first time in a while that you have physically disconnected the projector from power. If the power button on the projector doesn't come on its your power supply. Need to send it to a repair shop, or someone like me that can repair projectors.
Posted on Apr 22, 2010
Infocus Projector IN83 is overheating and shutting down every 20 minutes or so. Talking with online assistance suggested that I replace the bulb so I bought a $200 new bulb assembly and it has already...
I had the same problem so removed the bulb which is very easy, only 3 screws, found the wire mesh inside was covered in dust so vacuumed using a brush head attachment, removed all the dust & did the same to all the external vents too. The projector now runs smoother, quieter & does not over heat after hours of continual play. Hope this helps, Chris
May 20, 2011 | InFocus IN83 Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
Infocus x2...the bulb melts the small square lens even w/ fan on
there is more than one fan inside. one of them may not be working. also, if there is excessive dust inside, the heat won't leave. blow out all of the dust with canned air. if one of the fans are running slow, replace it. lastly, do not use an aftermarket lamp. get a good one from the comapny.
Jun 14, 2009 | InFocus Office Equipment & Supplies
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
My bulb went out on my infocus sp-4805. I bought a new bulb, and replaced it, and it worked...for five minutes. the picture went out, and it was overheated. I took some parts off, and sprayed can air in...
The fan is probably on it's way out and cannot produce enough air flow to cool the lamp. Replace the fan with the same ratings as the original and it should work fine. The only other thing would be a problem with the power supply not supplying enough power to the fan, but, a bad fan is more likely.
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projector getting too hot
comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
23 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
