Question about Clarion CZ500 Car CD USB MP3 Player
My Clarion CZ500 came up with an error that said "MCU UPG", drained my battery over the weekend, and now it won't turn on. How do I fix it?
While driving around in my car all of the sudden the display on my Clarion CZ500 said, "MCU UPG", and then stopped working. This display message stayed on even after turning off the car. Over the weekend it completely drained my battery at which point the display turned off. I charged my battery back up again but the unit has never turned back on since. How do I get it to turn back on? If I can turn it on then maybe I can follow the instructions here: http://www.fixya.com/support/t7406502-mcu_ulg_error_code_cz500_clarion_radio P.S. I bought the unit new from an online retailer, so I can't return it to an 'authorized Clarion retailer' under warrenty.
    New Friend:
Just had this issue on my CZ500 today. Clarion said my only option was sending it in for service.
I had it professionally installed, it's worked perfect ever since, and this error message pops up all of a sudden killing my stereo.
Posted on Sep 22, 2015
Call Clarion 800-GO CLARION That's what Im doing right now!! GL
Posted on Oct 12, 2012
  • myson45
    myson45 Oct 12, 2012
  • myson45
    Also I called a local dealer in my area and he said that I have to bring him the deck and he has to send it off to California pay them 200$ + 10 shipping fee, then I ll get me deck back, what a bunch of b/s! Clarion had to know about this problem.
Where do I find the MCU on my Kenmore h2plus washer?
  • 1 Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
  • 2 "F21" indicates a draining problem. Again, press the Stop button twice and take a look at the drain hose. Make sure it's not kinked, frozen or clogged.
  • 3 "SD" on the display indicates the machine has gone into its Suds Routine. The Suds Routine removes excess suds so that the garments rinse properly. It's not a problem, but can be an indication you've used a non-high-efficiency powder. Just let the SD routine complete and the draining will continue.
  • 4 Make sure the washer is level if it gets noisy or vibrates too much. Use the leveling feet to adjust the level. They screw and unscrew for adjustment. Make sure the shipping bolts were removed from the back of the machine if the machine gets too noisy. See the "Removing Transport System" section in the instruction manual.
  • 5 Check that you are using HE detergent if you spot leaks. Check that the fill hoses are tight and that the drain hose is secured to the drain pipe. Check that the drain isn't clogged.
  • 6 Make sure the load is balanced if the washer won't drain or spin--or if water remains in the washer. Redistribute the load.
  • Buy Custom Car parts.
    Jun 02, 2012 | Kenmore HE2 Plus Front Load Washer
    F06 error code
    Hi Bunny:
    F06 code will indicate a drive motor tachometer error; means the control is unable to properly detect motor speed and the machine will shut down.
    If a failure occurs during high-speed spin the door will be unlocked after 3 minutes. Potential Causes:
    * Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    * Check the Drive Motor
    * Check the MCU
    * Check the Wire Harness
    Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using Fixya, and have a nice day.
    Dec 14, 2011 | Frigidaire GLTF2070DS Front Load Washer
    How can I have a normal display on clarion cz500
    You'll probably need to contact a local car audio professional or Clarion customer support directly here:
    https://clarion.com/xe/en/user-support/inquiry/contactus
    Sep 27, 2017 | Clarion CZ500 Car CD USB MP3 Player
    What are the blue wires coming out of the wire harness for
    The wires are usually: Blue - Remote turn on for an after market amplifier Blue/White - Used to power an antenna that requires power to turn on.
    Apr 12, 2011 | Clarion CZ500 Car CD USB MP3 Player
    Clarion CZ500A won't power up. Following error
    Hey Adricat, did you get a solution to this problem? I have had this happen twice now, and each time it was replaced by the shop i bought it from.
    Mar 07, 2011 | Clarion Car Audio & Video
    How can connect bluetooth in clarion cz500
    Hold "D" button to enter the menu mode.
    By using the previous/next button select BlueTooth menu by using the D button.
    Use the volume to select auto connect.
    I am also including the link to the manual just in case this doesn't work. Bluetooth menu will be on page 21.
    http://www.clarion.com/us/en/MungoBlobs/370/422/CZ500_EN.pdf
    Jan 09, 2011 | Clarion CZ500 Car CD USB MP3 Player
    I was driving and my cz500 clarion in dash threw some code and stopped working, i tried resetting it and now it wont turn on, what should i do?
    What was the code? was it something like mcu ulg? the same thing happened to my stereo. i have the same one. I called the people who installed it but they said they have no clue about what i am talking about.
    Dec 18, 2010 | Clarion CZ500 Car CD USB MP3 Player
    Clarion came up with code not to sure exactly but had two sets of three letters, such as "MCG U.." something like that and then did not turn off. finally got the cords out of the back and now does not turn...
    I had the same problem and the dealer that sold it to me said to check the fuses. That happened to mine when the temperature hit minus 40. Have you fixed the radio?
    Sep 20, 2010 | Clarion CZ500 Car CD USB MP3 Player
    Clarion CZ500 Car CD  USB MP3 Player Logo
    864 people viewed this question
    Top Clarion Car Audio & Video Experts
    xxxxxx xxx
    Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
