Tv will not power on
TV is approximately 3 months old. All of the sudden will not power up. Check on multiple outlets, checked outlets as well.
  • 807 Answers
Take it back to the shop, if it's 3 months old it must be under warranty.
Posted on Feb 15, 2012
Agent Jason
  • 78 Answers
SOURCE: Connecting multiple A/V cables to 1 TV
Hi zantar412,
Yes, there are devices to help you. You should shop for an “RF Modulator.” While the intention of this box is convert an A/V signal to RF for older televisions, many modulators offer multiple inputs which can be chosen with a switch. Be sure to check both the input and output options on the box that you buy to ensure it will be compatible with your components and television.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 30, 2008
  • 22 Answers
SOURCE: Black Bars
Hi guys.  This is totally fixable and pretty easy if you have tech skills at all.  I performed this fix even before I found the following thread that will explain it, and it worked flawlessly!  Read it entirely and follow carefully.  this works on many different models of plasma's.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
sabreusa
  • 271 Answers
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
Posted on Nov 07, 2009
  • 909 Answers
SOURCE: tv is only 3 months old = tv won't turn on
I suggest returning to supplieras it will be under guarantee and if a third party does any work it will be voided.
Posted on Jan 02, 2010
SOURCE: No Picture on LG Tv. it is only 3 months old. I
The flashing may indicate a failed power supply. Or a bad backlight tube.
Only 3 months old? Any warranty?
Considering its age I would say a defective part or poor assembly is to blame.
Posted on Feb 05, 2010
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
My 3 month old Panasonic Plasma TV (TH-42PZ700A) has suddenly lost its accurate colour control (particularly noticeable on skin tones). Prior to this happening the skin tones were perfect. It followed the...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Aug 06, 2008 | Panasonic Televison & Video
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
No power, no nothing
Your problem either lies with the power supply or main board. I suggest you start with the power supply. Make sure you have standby (5vdc) power with the set plugged in. I would also check for any bulged power supply caps. I would also suggest you verify that you have a 110vac outlet in good working order!
Feb 06, 2013 | Philips 42PFL3605 42" Multi-System LCD TV
Why does my vizio lcd 47 in tv just suddenly turn off. I will be watching tv and suddenly it just goes off. The vizio power light then blinks steady for about 1 min and then the tv starts up again, as if...
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
I hope this solution helps you to fix your problem.Thank you and good luck.
Jun 13, 2011 | Vizio VO47L 47 in. LCD TV
I purchased a SUPRA 32 LED TV FULL HD Model No SLED32OT9001R from UAE 3 months back and from the last few days TV is not working even the power led at the front pannel doesnt shows power.
Be sure the power cord is plugged in to the a/c outlet fully. Take a table lamp and plug in the same outlet to verify power is good. If no power, check for circuit breaker tripped in main breaker box.
If problem seems to stay with tv, I would contact seller. You should have at least nine months of warranty left.
May 17, 2011 | Televison & Video
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
Will not turn on -- no power
Check for blown fuse inside if thats no then you need to trouble shoot the power supply
Nov 01, 2007 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
