Question about Seagate DB35 ST3160215ACE - 160GB - 7200rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal Hard Drive
I need the installation book to install it. - Seagate DB35 ST3160215ACE - 160GB - 7200rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal Hard Drive
  • 8,404 Answers
The power connector (Molex) has a red wire (one of four) - the data wire has a red stripe on one side - the red stripes go toward each other. If you have a 80 conductor data ribbonn cable, this is for "Cable Select" position in the shorting plug. If yours is 40 conductor, you are NOT cable select. The Master or '0' drive goes at the end of the cable while a slave or '1' drive attached to the plug close to the end plug. The other plug of course goes to the mother board. Look for a small '1' on the motherboard (red srtripe). Use either Cable Select (if appropriate) or Master (if appropriate) or Slave (if appropriate) when selecting the shorting pins on the back of the device.
For your info, the little connector you will find inside adjacent the Molex is called a Mini Molex.
The Master is where the device "C" should reside (and have your operating system). All other drive designations will be set by your BIOS.
If you need more help, go to www.seagate.com/support and look up your drive for complete instructions. I think they have downloadable "tools' there to help you as well.
I hope this information helps you ... Thanks for your quesiton @ FixYa.com
Posted on Feb 14, 2012
I need program to start my hard drive,, install program. (i)book 500 g. WD
You can find the install program here. Click on the link associated with your device and it will take you to a page with all the available downloads for it. Download the install ISO and burn it to a CD or DVD, whichever you have access to and capability to burn. After making the disk, insert into the machine you want to install the device on and run the install file.
May 09, 2011 | Western Digital My Book Essential Edition...
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
Need gps help
Download the MyBook_vista_windows7_Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Jan 25, 2011 | Garmin StreetPilot C330 GPS Receiver
How do you reset an apple macbook laptop
Don't worry just follow the below steps and you will be able to fix your problem
Back up your information to an external medium such as an external hard drive or a flash drive. The install process allows you to transfer current files to a fresh operating system (OS) install, but it is always best to be prepared with a backup of your files in case something goes wrong.
Insert the first install CD or DVD of the operating system software.
Restart your Mac Book or Mac Book Pro. Immediately hold down the "C" key as the computer reboots. This will cause your Mac Book to boot from the CD or DVD you inserted.
See the "Welcome" dialog that asks you to pick a language. It may also ask you to agree to the terms and conditions of the software install. Depending upon which OS version you are using, you might see the software perform several checks on your system. If you do not see this, do not worry.
5
Choose where to install the OS. You're most likely going to select your primary hard drive. If you have one or more partitions on your hard drive, you can select any of them as long as they are large enough.
6
Choose your install. You'll be presented with three options: "Upgrade," "Archive and Install," and "Erase and Install."
Choose "Update" to simply update the current OS install on your Mac Book. All your data, files and programs will remain intact.
Choose "Archive and Install" if you need to back up all the data on your system and import it into a fresh install of the software. You will need to reinstall much of your non-Apple software if you choose this option.
Pick "Erase and Install" if you want to erase everything on your hard drive and install a fresh version of the OS. None of your data will remain if you pick this option. This is effectively a factory reset of your Mac Book, as none of your personal settings or data will remain.
7
Choose the right setting. If you choose "Archive and Install," be sure to check the box to preserve your user and network settings. This will ensure your previous profile data is installed in the new software installation. Once you've chosen an option, select it. Click "OK."
8
Relax. The Apple OS install will take care of everything from this point. You may be prompted along the way with a few questions, but the install should be mostly automatic. When the install is complete, your Mac Book will restart.
9
Restore your data. If you chose "Upgrade" or "Archive and Install," the software will prompt you to migrate your old data to the new system. Follow the instructions to ensure your old settings and programs are transferred to the fresh install of the software.
Thanks.
Have a great day
Sep 17, 2010 | Computers & Internet
I can't load quick book 05' I keep getting the same error.
- close all programs
- use internet explorer to open http://www.adobe.com/products/flashplayer/ - download and install flash player.
- run quick book 05 installation again
Mar 22, 2009 | Intuit QuickBooks: Pro 2005 for PC
How do I install an e-book on a sansa e250?
you cant. It isnt designed to read file formats. Only video, mp3/wav music, and pictures. I'm sorry but you need a sony reader or kindle for the type of files you want.
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Mionet problem
The issue you are experiencing is account bug. You must reinstall MioNet and create a new MioNet account, then attach the My Book World to the new account. You will then regain your MioNet access.
http://www.MioNet.com/mbvista -- this is the download installer for MioNet which works for blue-ring My Book Worlds. The White-Light My Book World requires different software.
To create a new MioNet account, please use the following instructions:
Part A. Reset MioNet/Anywhere Access
1. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear. The username and password it requests will be the same as your MioNet username, and the original password used for MioNet (if you changed your password on our website, it does not update the My Book World).
2. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup", then choose "WD Anywhere Access settings". On the following page you will have three buttons to select: please click on the "Stop" button, wait until WD Anywhere Access status goes to "Inactive", then click the "Reset" button. Once the WD Anywhere Access Status goes to "Not Registered," (on older firmware, it will go back to Active), the My Book World has been properly reset. This will return the MioNet software on the My Book World to default settings. It will not harm your stored files.
Part B. Uninstall and Reinstall MioNet (on a computer located on the same network as My Book World)
1. Uninstall MioNet from one of your computers.
2. Insert your Western Digital installation disk or download MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
NOTE: You must use the installation disk or the link above to create your new account. Certain functionality related to the My Book World is related to the installer you use to register a new MioNet account. Failure to use the proper installer may result in the need to repeat this process.
3. Register as a new user. You will need to specify a new username and E-Mail address.
4. During the installation, MioNet should detect the now reset My Book World. Please add it to your new account.
Part C. Uninstall and Reinstall MioNet on your other computers
1. Uninstall MioNet from your other computers.
2. Install MioNet using the Western Digital installation disk or downloaded from MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
3. Register as a current user with your new account's information.
Please let us know what your new account name is and we will follow-up with additional information. We will also send you instructions on how to reset that account's password.
Oct 08, 2008 | Western Digital My Book Essential Edition...
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Seagate DB35 ST3160215ACE - 160GB - 7200rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal Hard Drive Logo
51 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
