Question about Optoma EzPro 610H Multimedia Projector
Optoma EzPro 610H Multimedia Projector Display is all white
I had a computer hooked up through s-video. I fell asleep on the couch and left the projector on all night. The computer was shut down. When I woke up 6 hours later, the projector was still running (not timed out) and the display is all white. I have tried going into both the video and s-video ports with the same result. I get audio but the video is all white. I noticed also the normally on startup it shows a blue screen that counts down lamp warmup or something. It isn't doing that and it won't bring up the menu options either. When I look through the fan holes I see that the blue, green and red are all on. I'm assuming that is what is making the white. HELP! (please)
    New Friend:
  • 20 Answers
Your projector is LCD based. That is, basically, a tiny panel is a computer monitor with a lamp behind it to shine through the panel and lense, onto the screen. This all white screen means the pixels of the LCD are all "deactivated" allowing all the white light through. This happens on computer monitors from time to time. I cannot find a blind reset, meaning there's isn't a method of holding down a series of buttons to "reset" the projector.
aside from calling support, as their manual is useless, I would recommend powering the unit off and then unplugging all cables, including power.
Press and and hold the power buttons for 20 to 30 seconds to see if it clears up your issue. Sometimes, after unplugging the unit and pressing the power button on the projector will briefly light the panel lights and then they fade. This may be enough to drain enough power to force the projector to reset to normal conditions.
If if that doesn't work, I'd recommend leaving it unplugged for a day or so and try it again. Beyond that, the controller board for the display may have failed. It shouldn't be the case, but it is possible.
However, I feel the unit needs a simple reset, which normally you'd do though the menses, which obviously possible.
Posted on Apr 02, 2017
bigg t
  • 640 Answers
SOURCE: Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Posted on Aug 28, 2007
SOURCE: Projector problems
Hi, I have an Optoma EzPro 751 that had a similar problem, although it got progressively worse until it only took about 5 minutes to begin acting up. I was really frustrated, as the bulb only had around 600hrs at that point and the picture was bright. After some searching of forums like this, I found someone else with the same exact problem, but with a Dell projector (made by Optoma).
The culprit was LOTS of dust, built up on the circuitry, built up on the optics, built up everywhere! Solution: carefully open up the case and use canned air or an air compressor with a blow nozzle attachment. (warning-compressor air MUST be filtered first as it otherwise contains moisture and other harmful suspended contaminants)
I was at the end of my rope, and this really worked for my problem. It's worth a try, but BE CAREFUL! There are delicate parts in there you don't want to blast apart with air. If you use the cans, buy several as it took me quite a bit of blowing with a compressor regulated at 90psi to get it all out. Good luck!
Posted on Aug 11, 2008
SOURCE: EZPRO 610H...has a red shadow
this is ghosting, caused by interferance. cheaper cables tend not to have metal sheathing and those ferrite RF suppression thingees on the ends, which prevents this problem.
also, avoid running your signal cables next to power cables. If your cables are long (say more than 10m) this may also cause problems.
Posted on Sep 01, 2008
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Posted on Dec 22, 2008
This is it (in the USA)
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
Optoma EP751, Just got a white boarder from top to bottom. Left.
try to reset.... or clean the board between av board and main board.
Oct 29, 2009 | Optoma EP751 EZPRO DIGITAL PROJECTOR...
Full Desktop does not appear, video does not show.
You must tell the laptop to change display mode--there are 3...Normally, the key-press is something like "function key, F4"--look for a small tv screen symbol on one of the "F" keys--default mode is "laptop only", Press and hold "fn" and then press the appropriate "F" key, the laptop will switch to "laptop/external display". Another set of key presses will get "external display only" mode. And, finally, the next sequence will bring you back to the default mode. Make sure you turn on the computer and *then* turn on the projector to head off any sync probs.---Rick
Sep 21, 2009 | CTX Optoma EzPro 710 Multimedia Projector
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
How can I adjust my screen as of now one side is high and one is low,please help
Hi dave4455_uk
You will see two feet on the bottom of the Projector that can be adjusted for height purposes.
Thanks for using Fixya !
Apr 29, 2008 | CTX Optoma EzPro 610H Multimedia Projector
Nov 22, 2007 | CTX Optoma EzPro 610H Multimedia Projector
Projector problem
it has a faulty rca jack provable. You are lucky you have the computer jack. You can get a little vga to rca adapter i think.
Oct 14, 2007 | CTX Optoma EzPro 610H Multimedia Projector
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Optoma EzPro 610H Multimedia Projector Logo
57 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
