Question about PC Chips M957G Motherboard
_motherboard_wiring_diagram speaker,pwr sw,reset sw,hdd led,power led wire connections
Wires came off need to put back in correct place
  • 669 Answers
Here is a link to the user manual, i think page 16 is what you are looking for.
http://download.ecsusa.com/dlfilepcc/manual/m957g/957G_10A.pdf
Posted on Feb 14, 2012
SOURCE: need the power led hdd led reset sw and m switch
grguwetgwoig6roie3gsoufy;aseuywiefiffiw;i;euwy;a44rwysufdhjdjdfdjdjdhdjjh
Posted on Jun 06, 2009
KingDWS
  • 1606 Answers
SOURCE: pluged in pwr and restart and hdd led but where is
speaker connectors are strange on most boards. They tend to be 4 in line pins but only the two outer ones are used. So you will see
0000 pins shown for the speaker connector but the only ones you use are the x's - X00X or the two end pins.
Posted on Jul 30, 2009
  • 336 Answers
SOURCE: CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Posted on Aug 22, 2009
dwane4444
  • 219 Answers
SOURCE: PC Chips M756LMRT+ PII/III/Celeron Slot1/Skt370
I have the same problem! The PW SW, and Reset SW can go either way round. The LED leads do need to be correctly placed. If there has been any doubt in the past I have tried each way until one way works - this has never caused me any problems. One tip is that usually the marking on the connectors all face the same way.
Posted on Oct 29, 2009
linktriscuit
  • 89 Answers
SOURCE: How connect H.D.D. LED, Power led-, Power led+,
go to the link below and download the manual.
http://www.pcchipsusa.com/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=354&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
Posted on Mar 12, 2010
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
Nov 30, 2008 | E-Machines (308714) Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
Jul 28, 2008 | E-Machines eMachines Desktop PC
PC Chips M957G Motherboard Logo
192 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
