Question about Tamron Cameras
Tamron AF 18-200MM XR Di II LD dust inside; how do I clean?
Several specs of internal dust on front lens. Is it accessible for cleaning? Or any ticks to get it out without taking lens apart?
  • Tamron Master
  • 3,289 Answers
Dust and other small debris is drawn into the lens due to the vacuum created when zooming in. You can reduce the chances of drawing in dust and debris by slowly zooming in as opposed to rapidly zooming in.
Now that you how it gets in and how to help prevent it from getting in again, comes the bad news. There's really no way to disassemble the lens to clean it up at home. These are precision optics with many small moving parts that really need to be serviced in a dust free environment. You best bet it to contact Tamron (or authorized servicer) to learn how much it will cost to be cleaned by them. This will keep the warranty (if any) intact, too.
Posted on Feb 14, 2012
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: bought a tamron 28-300mm Di LD lens for my Canon
Nothing you can do. The Tamron is not compatable with your camera. So the focus will be slower
Posted on Apr 24, 2009
  • 134 Answers
SOURCE: I broke the top lens on my Tamron AF 70-200mm
Contact Tamron USA via their web site or a phone call to get a price quote for the front lens assembly. However, I would strongly suggest that instead you allow Tamron to repair your lens since more than likely the internal roller glides have been compressed due to the impact. This would allow the front lens group to wobble a bit while focusing and zooming, and this would seriously affect the image quality.
Posted on Apr 26, 2009
  • 175 Answers
SOURCE: Tamron AF 28-200mm 3.8 - 5.6 Apherical LD that was
It will fit but no AF.
Posted on Jan 06, 2011
Tri3mast
  • 747 Answers
SOURCE: Drop my Nikon D100 camera with a Tamron AF
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
Posted on Jan 28, 2011
How do I clean inside a Ricoh rikenon 70mm to 200mm zoom lens.
Unless you have a lens collimator and other equipment to ensure proper alignment when you reassemble the lens, don't even think about taking the lens apart. Take the lens to a reputable camera shop and let a qualified and properly equipped tech handle the cleaning.
Aug 30, 2016 | Ricoh Cameras
How do I disassemble a 20 zoom lens for a Sony V1U camcorder?
Jeff, to assemble a lens, you need a collimator to make sure all optical elements ate correct in place. You need skills and a manual, to be able to adjust all lens elements in a correct order.
Asking this question, I'm sure you don't have a manual, a collimator and you miss the skills. So if you don't want to end up with a pile if glass, unable to act as a lens, please don't try this yourself. Even Sony will not reassemble the lens if you took it apart. If you really need a lens to b cleaned, please bring it to a Sony certified service centre and ask them what it will cost to clean / replace the lens.
Oct 14, 2014 | Sony HVR-V1U Mini DV Digital Camcorder
How can I clean the inside lens of my Ricoh cx5 camera?
Once you start blowing air from aircan (duster) it will move the dust sitting on the barrels' surfaces of the lens. The dust specs will end up on the interior of the lens glass even in larger quantities. The only way to clean it correctly is to take apart the lens and blow the dust out and assemble it back. If the same camera is listed on ebay under $50 buy another one with a clean lens. Sell yours on ebay for parts the difference will be around 15-20 dollars. Not a bad price for getting a cleaner version of your camera. You may even make money by buying a better camera cheaper than you can sell yours. If you camera is still valued at 100-200 range find a cleaning service on ebay for $30.
Jul 15, 2014 | Ricoh CX5 Digital Camera
How to clean the focusing lens?
First question: where is the dust?
If the dust ist outside the cam: no problem. Try a soft brush and remove bigger particles, then take a thin microfibre cloth and clean the dust film on the lens. Be careful - every sand particle scratches the coating, so use the brush!
If the dust is internal it's more complicated.
May be the dust is on the focussing screen. If you dismout the lens, there is a litte lock on the top inside the cam. Do not open without having special tool. Each fingerprint on this little plastic plane is not removable. It's an extreme sensitive fresnell lens.
Don't try to clean that with cloth or brush. Only airflow is allowed.
If this dosn't help - use the Canon service or replace the focussing screen with a new one (as Example Canon EF-D).
Dec 31, 2010 | Cannon EOS 50D Digital Camera
I have some dust on the sensor of my fx500. not sure how it got there, but it's there. anyone tried taking one of these apart for cleaning? is it fairly straight forward?
I have the same camera and the same problem as I always keep the camera with me in my pocket. The camera can be taken apart and cleaned if you have a clean work space. I would not attempt this if you do not have experience separating electronics with delicate ribbon cables. Wants the camera is apart it is easy to see why this happens as there are several gaps in the lens barrel. If you have patience it can be done but I recommend as much of a dust free environment as possible, some cleaner for a DLSR sensor and some air duster. When I tear my camera down I start with the bottom and work my way to the sides. The most difficult part about separating the camera for me is the top portion of the camera where the zoom control an on off switch is located is attached permanently to the flash and the flash capacitor. This needs to be wiggled with the utmost care and pulled straight up and out of the camera. Once the camera body, sides front and top are separated the LCD screen lifts up and there are a couple of screws that screwed directly into the back of the sensor mounting bracket area once these screws are removed the sensor is easily accessible. Again you do not have experience with not touching anything while you're doing work like this do not attempt this. Once the sensor is pulled up a can be dusted and cleaned my typically blowout the lens barrel with the air duster, obviously making sure that you do not tilt the can because even the slightest residue will set you back even further.
Nov 15, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
My Olympus FE-230 makes buzzing noise when switched on and lens goes in and out and won't switch off and won't focus
Check for specks and chips on the lens first, if there are spots in the images. Take the lens off the camera and look through it at a low-level light source. If there is dust or lint, clean the external elements according to Olympus recommendations. Look through the lens again. If there still are spots, there may be dust on the internal elements. You will need to take the lens apart to clean each lens element. Taking the lens apart is a delicate procedure. Use Phillips-head screwdrivers or the Japanese crosshatch type. Lay out the lens and screwdrivers on a soft, lint-free cloth, and place each part of the lens in the correct order so that you can remember how to replace them. Clean each element with soft lens tissue or cloth or use a manufacturer-specific kit.
Aug 28, 2009 | Olympus FE-230 Digital Camera
Trash inside my monocular
Blow it out with canned air-- if the lens is dirty follow these instructions--
http://www.televue.com/engine/page.asp?ID=143
May 08, 2009 | Tasco Specialty 25x30 1AGST Brass Spyglass...
Toshiba reads no disc
Dust infiltration is a likely culprit. Unplug the unit, open the case. Take a cotton swab and wet it with a small amount of glass cleaner. Gently wipe the laser lens several times without applying pressure, then use the other end to finish cleaning it off and to dry it. Often, so much dust gets inside these units and coats the objective lens it can't see the disc anymore. Give it a try, might work after this operation. I've fixed many CD & DVD players this way. If that doesn't work, take a can of compressed air and blow out dust from inside the laser by pointing the nozzle to the open space between the lens and the lens cover. Hold the can at least three inches away so as not to damage the internal workings of the laser assembly. Several short/sharp bursts of air might dislodge dust that has accumulated inside the laser housing.
Mar 05, 2009 | Onkyo DV-S535 DVD Player
Dust
HI
If this is not the DG type what you do is to remove the name ring you can pleel it of it will restick
under the name ring you willsee two holes to use a compus to undscrew this ring do not put
to much presher on the ring when unsewing it next you will be able to unscrew the front element
just clean and blow out the dust out then rescrew all .
Jan 10, 2009 | Sigma 17-35mm f/2.8-4.0 EX Aspherical for...
Cleaning the inside lens
To access the inner optics on these compact digital cameras the lens must be disassembled from the inside out. Usually the camera casing has to be removed, boards and connections moved out of the way, and the lens assembly actually removed from the camera. At that point the lens can be taken apart and the inner optics accessed. In other words, yes, this is a job for a professional. It is also probably not worth the cost just for a couple specs of dust. These lenses are not sealed. This is why the dust gets in there to start with. If you get a can of compressed air and carefully blow into the gaps between the lens parts in different directions somtimes you can get enough air through to blow off the inner lenses. This does not often work though. David Millier Advance Camera Repair
Mar 12, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
Cameras Logo
412 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
