Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Direction for machine - Bosch Nexxt Premium WFMC6400UC Front Load Washer
My machine will only sew backwards! What do I do?
sewing machines sew in one direction
the reverse sewing direction is achieved by reversing the direction of the feed dog under the material
this is achieved by a lever or knob on the front of the machine
IN your case I suspect that it has been changed unknowingly
Jan 10, 2016 | Kenmore Sewing Machines
I can't replace my needle,it will not go up far enough for the screw to hold it.
try rotating the needle so the flat side is toward the machine .
Oct 22, 2015 | Sewing Machines
WHAT is causing my Westinghouse Top Loader Washing Machine model LT809S to only agitate in one direction ??
problem with the direction control relay or power board
call a technician to diagnose properly
Jul 21, 2015 | Westinghouse Washing Machines
LG Model WP-9241 Washing Machine - Wash tub spins in only one direction
wash tub spins in only one direction it cannot spin in other direction
Dec 21, 2014 | LG Washing Machines
How do I change the direction that the arm travels on an Iron Mike Machine?
Iron Mike Pitching machines can be configured for baseball, fast pitch & slow pitch softball.
Aug 30, 2014 | Iron Mike MP-5 Pitching Machine
How do I decalicy the Starbucks Italia Digitial?
Use a coffee machine descaling liquid or powder. Follow directions on product. Add it to water container on machine and push the descaler button "bottom right" on machine. Follow directions on screen.
Jul 17, 2011 | Starbucks Saeco Italia Digital Barista...
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
Feb 01, 2009 | Juki MO-655 Mechanical Sewing Machine
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
