How i connect my mexmark x9350 to my dell computer with out cd
The list of drivers are here download then just follow instructions when to install the printer
SOURCE: I have a lexmark x9350
Do you need the full disk or an .iso or just the drivers for the printer? If you need just the printer then you can go to this web site: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 and select the OS that you use and download the driver.
SOURCE: (Lexmark X9350) Don't have the
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,double click on the file, then if you get introubles,follow theinstructions below to reset and reinstall drivers:
Note:some printer does not work on Vista
SOURCE: Windows 7 cannot find Lexmark Printer
Hello. I am going to talk you through the process to remove your old printer driver and then download and run your new printer driver. go to this site: http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US&question=x9350+driver&productCode=LEXMARK_X9350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X9350&searchid=1260945823003#1
Begin at the top where it says upgrade to windows 7 in red. click on that. then just follow the prompts and you will be all set. Regards, Joe
SOURCE: My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Please visit the Lexmark website to download and install the Lexmark X9350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
