Question about Kodak EasyShare M1093 IS Digital Camera
Everytime i put SDHC memory card in camera it shuts off... canon m1093 is
It says something like "memory card intersted or removed, power off" or something like that- but i've put the memory card in before while it's off and it wont turn on either.
    Scholar:
  • 51 Answers
I've run into this problem with off brand or damaged SDHD memory cards. I just had another SD card go bad on me tonight. It happens. Sometimes they can become corrupted, and need to be low level formatted, and then sometimes formatted by the camera again before use.
Check out the SDHD card in something else, if you can. If it appears just fine there, then it may just be incompatible with the Kodak camera.
Try another SDHD card to see if it operates properly, which will most likely resolve the issue for you.
Posted on Feb 14, 2012
  • jane doe Feb 16, 2012
    Thank you! I borrowed a memory card from my sister and it now works again.
Cannon SD1100 IS Digital Camera The Camera reads " Card Locked". The Maual's solution is to slide the switch up on the memory card. Did that still won't work. When I go to the Menu, the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Feb 25, 2011 | Canon PowerShot SD1100 IS Digital Camera
I have a Canon power shot A520 , couple of years old. Just started saying "no memory card", even tho I've replaced the memory card w/ a new one and changed the batteries. When I try to reformatt...
Is the new card more than 2GB? 4GB "SD" cards are almost always actually SDHC (high capacity) cards. Anything larger than that certainly is (and a few 2GB cards as well). SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
Feb 01, 2011 | Canon Cameras
The camera will only work witha 1GB memory card, we have tried to install a 5GB memory card and the camera shows "memory card error" yet when we try to install the same memory card in another...
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. Anything over 2GB is SDHC.
Nov 25, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
I have a canon power shot SD100IS & and it keeps telling me, "card locked"..what does this mean?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 14, 2010 | Canon Cameras
The canon says "memory card
Nov 12, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Oct 24, 2009 | Canon Cameras
Kodak EasyShare M1093 IS Digital Camera Logo
168 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
