Simpson 36P450 Washing Machine continuously Draining as it fills. Request advice. Am Navy Electronics Tech, but don't have Repair / Maintenance manual for the washing machine
  • jo07 Apr 27, 2009
    intuitive eco washer continually draining. Hose runs from machine into outlet in floor and then out drain. Has always had this configuration, but only today started siphoning.
  • Anonymous Mar 13, 2014
    have problem with my machine it is not taking the powder from its department
    Scholar:
  • 147 Answers
It cant drain if you oulet hose is higher than the water level. Raise your drain hose up above your water level. I was pmel (calibration) in the air force..Love it.Went to school at port huneme (navy) school
Posted on Oct 25, 2008
  • jaideep singh Nov 11, 2011
    perfect and simple solution provided by ***** 1964 thx mate
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
GE WWSE5200B Top Load Washer does not drain or spin
Jim, we have same problem with Simpson top loader washing machine.
Our repairer eventually diagnosed it as a problem with the electronics but it can't be fixed. So we have a 3 year old machine with good pump , motor, gearbox etc but need to buy new machine now. Yours might be similar problem. Don't buy a simpson. Sorry, this is just what we've been told.
Jenny
Dec 03, 2011 | GE WWSE5200B Top Load Washer
Operating instructions for 36P450 Simpson washing machine
I have a Simpson espirit 450 andthe agitator has a hole. I have beensent a new one but have no idea how to remove the old one. I can loosen the bolt at the bottom but can't can remove the bolt. Unsure why or what to now ? Would love some help... Thank you
Dec 01, 2010 | Washing Machines
Hi I have a Simpson 7.5kg top loader machine model no 22s701E. The water keeps continually filling. I have to turn the taps off for it to stop otherwise it overflows everywhere.
Water inlet valves operate when power is supplied to them. If you turn the machine off or pull the plug and the water stops it means that the inlet valve is ok. If the water continues to run with no power to the valve then the valve is faulty..
Replacing a crook inlet valve is not a big job for a tech..
Good luck....Nomess
Aug 03, 2010 | Washing Machines
Washing Machines Logo
493 people viewed this question
Top Washing Machines Experts
