Question about Measuring Tools & Sensors
How to zero the mitutoyo udr 200 dro - Measuring Tools & Sensors
2 Suggested Answers
  • 583 Answers
SOURCE: I need to adjust a 293-761-30 mitutoyo micrometer.
there should be a small silver spanner with a couple of pins protruding to do that with comes in the box if you haven`t got it come back to me
Posted on Aug 16, 2009
How do you put a preset in Mitutoyo uni-mics?
Normally you would adjust it to the part being measured then press the 'Zero' button to zero out the display. Now every time you measure the same type of part, it should read zero or the dimension plus or minus from that zero point.
Nov 20, 2012 | Mitutoyo 317-351 Digital...
How to reset depth micrometers , any style , easiest method for Mitutoyo line
The nut on the end of each rod is for calibrations. On a clean flat surface check your reading at "0"and see if adjustment is needed either left or right on the nut for getting before zero or after zero readings. Adjust the nut as little as possible and re check for zero multiple times because the nut is sensitive. hope this helps.
Jun 29, 2011 | Mitutoyo Depth Micrometer 0-6"
I HAVE A MITUTOYO 6 INCH ELECTRONIC CALIPERS,MODEL # CD-6 CS. IT NO LONGER CAN SET ITSELF TO ZERO WHEN THE JAWS ARE CLOSED AND IN THE ZERO POSITION. PRESSING THE ZERO ABS CODE FOR 2 SECONDS AND THE...
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.
The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
Dec 24, 2010 | Mitutoyo Dial Calipers
Gage will not hold zero setting.
This is not uncommon for a gage like this with such a close tolerance. A small change in temperature can cause this gage to jump off zero due to the thermo-expansion of the materials in the gage itself. If you were to set this gage on a part, zero it out, and just breath on it, the temperature change created by the heat in your breath will cause it to change. The gage is not faulty (unless it is reading way out of range), it instead is probably giving you a very exact reading.
Dec 09, 2009 | Mitutoyo 0-.5" FLAT.00005" MITUTOYO...
Aug 15, 2009 | Mitutoyo 293 831 Electronic Digital...
How to adjust Mitutoyo 505-101 caliber
You don't. What you did to adjust zero is what you do to adjust zero. Do not "go inside to adjust the dial". If the dial reads zero when the jaws are shut there is no problem.
Mar 18, 2009 | Measuring Tools & Sensors
Need to get my good old DRO to work again.
try to clean up the linear scale first, maybe the light did not reflect because of dirt or dust
Feb 22, 2009 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
87 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
