Question about HP PSC 950 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
Even when I press enter and the printer aligns the cartridges and prints out the test sheet, it still says Press Enter to Align Cartridges. I also tried opening the top of the printer and closing it. Same thing happens. I also tried turning it on and off. I can give it the order to print something from the computer and it prints fine.
  • 2 more comments
  • aclark189 Oct 25, 2008
    Why has no solution been posted?
  • Lisbeth Sigh Fehrmann Oct 31, 2008
    The same, won't copy but will print from pc. Keeps saying that alignment failed.
  • Anonymous Nov 01, 2008
    hp should stand for a hope and a prayer, I'm buying a lexmark. HP has refused tech support and kept me on hoold for 1 hour 45 minutes for this issue. Last year they were able to give me a reset code that worked now they are trying to sell me a new or refurbushed printer. No more money to HP!!! plus ink refills cost about 35$ and you can count on having to buy 3-4 a year, Lexmark here I come.
  • poseidon769 Feb 10, 2009
    I have a HP PSC 950 All-In-One-Printer. After installing the cartridge I pressed enter to align cartridge and only the black color showed on the sheet but not color & an error messages shows saying alignment failed, press enter to align catridge. How can I solve this problem?
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Posted on Feb 19, 2009
  • TechHelpNYC Feb 11, 2011
    I pressed and held the Setup button and then pressed the option button. Problem cleared, I am a happy camper.
Even when I press enter and the printer aligns the cartridges and prints out the test sheet, it still says Press Enter to Align Cartridges. I also tried opening the top of the printer and closing it. Same thing happens. I also tried turning it on and off. I can give it the order.
Posted on Nov 10, 2008
Aclark189 I posted the following problem on October 25. Even when I press enter and the printer aligns the cartridges and prints out the test sheet, it still says Press Enter to Align Cartridges. I also tried opening the top of the printer and closing it. Same thing happens. I also tried turning it on and off. I can give it the order to print something from the computer and it prints fine.
I was disconnected from my first on line chat with tech support, but I was able to complete my second on line chat with tech support. I was advised that I had to replace the empty color cartridge, and when I did that, the copy function worked.
Thanks,
Annie Clark
Posted on Nov 03, 2008
    Novelist:
    Scholar:
  • 111 Answers
There are quite a lot of reasons that ink cartridge alignment can fail. Fortunately, HP.com has documented these problems and the solutions:
Ink Cartridge Alignment Solutions
Good luck and post back your results.
Posted on Oct 31, 2008
  • tripwire45 Nov 10, 2008
    lazymz, did you click the link I previously posted and read through all of the contents of that page? Annie Clark (Guest) found out that she needed to replace any empty ink cartridges in her printer to get alignment to work. Also, if you have a machine that does semi-automatic alignment, once the page prints, you'll need to put the alignment page on the scanner bed, print-side down, and make a copy of it to complete the alignment.
    I'm pretty sure (but not positive) that the instructions are printed on the alignment page itself. If not, go to the link I previously posted, open the web page and scroll down to Step four. Then continue to scroll down a bit more until you see the subtopic, "Models with a semi-automatic ink cartridge alignment". Follow the instructions and see if that helps.
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning ........it will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Sandipk
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
556 people viewed this question
Seeker5211
Seeker5211
