Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Cleaning the filter on frigidaire ultraquiet dishwasher
  • Official Brand Answer
  • 2,267 Answers
Hello Friend,
I see that you are wondering how to clean the filter on your Frigidaire dishwasher, model# FDB1050REC. The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth.
The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones, and pits. To remove this glass trap, grasp the handle, lift out, empty it and replace it. Hope this helps.
-Best Regards-
WP
Posted on Apr 08, 2014
3 Suggested Answers
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
Posted on Jun 09, 2009
mc1bean
  • 3053 Answers
SOURCE: Dishwasher- Frigidaire GLDB958 . I took the filter
Hello, ron
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Frigidaire ultraquiet III dishwasher not draining
Will the drain hose drain into a bucket? If so the garbage disposer is probably plugged.
Feb 07, 2015 | Frigidaire Dishwashers
Clean the dishwasher filter
Hey friend, thanks for your post!
From my understanding you would like to clean your filter inside of your Frigidaire dishwasher. Normally, to access the filter you need to remove the lower spray arm and pull up on the tab for removal. I hope this information is helpful. -Matt
Sep 24, 2014 | Frigidaire Dishwashers
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Water will not drain out at all left will a big
often times the drain hose improperly installed .the hose needs to have aloop in it where it comes up above sink drain. if this is wrong ,take hose loose and clean out alsoconnection at disposal.
Jul 02, 2009 | Dishwashers
Fridgidaire UltraQuiet III dishwasher model FDB750RCC0
First thing to check is to make sure the dishwasher is getting water.
Dec 03, 2017 | Dishwashers
hi there,
can you supply me with the exact model # off your d/w please?
Mar 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
284 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
