Question about Myron & Davis ADM169GY 7 Inch Flip Down Monitor with DVD Player for 2004+ Ford F-150 Series Trucks Car Video Player
Directed 10.2 I have had 2 of these installed and have had the same problem with both.... Both time after about 3 weeks installed I will notice that when I start the truck the dvd player turns on automaticlly (where I would usually have to press the power button) The screen is white with lines running thru. It will not power off until I kill power to the truck. Nothing works on the dvd player it just keeps the white screen. We have a 2004 GMC Yukon with 2 headrest monitors and one flipdown. Driver side headrest stopped working sometime ago but yesterday passenger side quit working yesterday and now although rear flipdown still works there is no sound. Is there a way to at least get sound? I would love to know if there is a way to determine what the problem is with the monitors as well. There is power getting to both monitors.
  • 6,487 Answers
First tho check here is the connection , because there's a possibility that you have a bad conenction or some problem with the wiring that you may want to check for this.
Posted on Oct 25, 2008
  • 136 Answers
Remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
What time is the Viet Nam documentary on tonight ?
The Vietnam War
PBS, 8 ET/PT (times may vary)
Ken Burns' latest documentary series is an intense and extensive look at the Vietnam War, its causes and its aftermath. Co-directed by Burns and Lynn Novick, the 18-hour work will air in 10 parts on PBS, this week and next. The first, "D?j? Vu," premieres tonight, and digs into Vietnam's emergence from a century of French occupation as an independent but divided nation. The next four episodes will air nightly through Thursday. while five more are due Sept. 24 to 28.
Sep 17, 2017 | Cell Phones
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
When will I notice an improvement for my pet's skin when using a supplement?
In most cases you notice the change after a couple of week but there are rare cases that you won't see any change for 10 weeks, the maximum time you'll need to way is 12 weeks in order to exam if the certain supplement works for your pet.
Aug 09, 2012 | Pets - Others
How long do I need to work out with a medicine ball to see results?
Effective workouts with medicine balls should last between 30-45 minutes, 2-3 times a week. Each session to consist of 8-10 different exercises with 2-3 sets of each. It won't take too long for you to begin noticing results.
Aug 05, 2012 | Exercise & Fitness
Fix timing belt and reset cam mark front and rear
Welcome to
Due to the amount of images FixYa can not handle them into one thread. Please e-mail me for the diagrams (PDF Format) at
Timing Belt Service 2002 Kia Sedona 3.5 liter
1. Remove the engine cover
2. Remove the drive bell.
3. Remove the idler pulley, crankshaft pulley, power steering pulley and tensioner
4. Remove the upper and lower timing belt cover.
5. Support the engine with garage jack or special tool, and then remove the engine
mounting insulator.
Caution: Take care not to deform the engine oil pan.
Image 1
6. Remove the auto tensioner.
Notice: Rotate the crankshaft clockwise and align the timing mark to get the No.1
cylinder's piston be in TðC position (compression stroke). At this time, the timing
marks of the camshaft sprocket and cylinder head cover should coincide with each
Image 2
'. Remove the timing bell.
Notice: When re-using timing bell, make sure of marking the rotating direction on
the belt so as to install correctly.
Image 3
Method of installing timing bell and auto tensioner
Image 4
1. Install the idler pulley to the engine support lower bracket.
Image 5
2. Install the tensioner arm, shaft and plain washer to the cylinder block.
Tightening torque: 35 -55 Nm (350-550 kg-cm, 25.82 -40.57 ft. lbs.)
Image 6
3. Install the crankshaft sprocket.
Notice: Confirm if timing marks coincide with.
Image 7
Caution: Align the spacer with a pin, and assemble it exerting even force not to
deform the crankshaft sensing blade.
Image 8
4. Install the camshaft sprocket. Align it like initial state as shown.
Caution: When installing camshaft sprocket, tighten the bolt holding hexagonal
part of camshaft to prevent it from tuning.
5. Install the auto tensioner to the oil pump case.
Image 9
Caution: At this time the auto tensioner's set pin should be assembled completely.
Image 10
6. Align the timing marks of each sprocket and install the timing bell, maintaining the
proper belt tension between each shaft in this order. Crankshaft sprocket -> Idler
pulley -> Left bank exhaust camshaft sprocket -> Left bank intake camshaft sprocket
-> Water pump pulley -> Right bank intake camshaft sprocket -> Right bank exhaust
camshaft sprocket -> Tensioner pulley.
1 As a result of this, position of No.1 cylinder comes to compression TDC.
2 As each camshaft sprocket tends to rotate by itself, pay attention not to injure
fingers or other bodily part. Especially be careful with the right bank.
3 In case the right bank camshaft sprocket rotates excessively, be cautious not to
rotate more than the initial stable position. Always align timing mark of rotating
sprocket by turning it reversely. In this case, pay attention not to rotate It
reversely from the initial position. (if. with one sprocket fixed at No.1
compression TDC position, the other sprocket is rotated one revolution
clockwise or counterclockwise, then the intake and exhaust valve might intetfere
each other)
7. After installing the timing bell, exert the reverse directed force to the right bank
exhaust camshaft sprocket to give tension on the belt. Holding this state, recheck it
each timing mark is correctly positioned.
S. With tensioner pulley slightly pushing the belt down, tighten the center bolt
9. Pull out the auto tensioner set pin
How to adjust timing belt tension
1. Tension setting (While auto tensioner is not operating: And set pin being kept
1) After rotating crankshaft 1/4 revolution reversely, rotate it clockwise to position
No.1 cylinder at TDC. Then, loosen the center bolt and give the belt 50 kg-cm of
tension with tensioner pulley socket (Two pins are attached) and torque wrench.
While maintaining this state, tighten the center bolt to the standard torque.
Center bolt standard torque 43 - 55 Nm (430 - 550 kg-cm, 31.72 - 40.57 ft. lbs.)
2) Pull out the auto tensioner fixing pin.
2. How to check tension (While auto tensioner is operating: and fixing pin being
1) After rotating crankshaft 2 revolutions clockwise to position No.1 cylinder at
TDC wait for about 5 minutes, and measure the amount of protruding of the auto
tensioner rod.
Caution: This is "leak down" time for the auto tensioner rod to protrude 1mm
when tension caused by rotation of the crankshaft has changed.
2) Check if the amount of rod protruding is in the range of 3.8 -4.5 mm.
3. Recheck if each sprocket is within the specified range.
Notice: ¡fit is not within the specified range, repeat from procedure 6 as service
procedure of timing bell and auto tensioner installation method. Refer to Timing
Belt; Service and Repair.
Thank you for using
Regards, Lee Davidian
Dec 13, 2010 | 2002 Kia Sedona
How to install audio drivers for lenovo y430
Hi Kasinaidu527,
Installing audio driver on your computer is so easy. All you have to do is to go to the official download site then download the driver that matches your operating system. Don't forget to restart the computer so the installation can be completed. I prepared some instructions below so you can install the driver in no time.
1. You can download the driver here.
2. Now after clicking the link, you will be directed to the download site. Please look for the audio section. You will notice that it has 3 OS. Please make sure to download the driver that matches the OS of your computer.
3. Download the .exe file to your desktop so you can access it easily.
4. After downloading, install the driver then restart the computer.
Hope it helps.
Thank you for using FixYa.
Aug 18, 2010 | Lenovo 3000 Y410 Laptop
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Oct 19, 2009 | Viper 160XVL Viper 160XVL Remote Start...
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Directed 10.2
just found why. there is nothing u can do. unit needs repaired.
Dec 07, 2007 | Car Audio & Video
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Oct 17, 2007 | Directed 1100d Car Audio Amplifier
Car Audio & Video Logo
206 people viewed this question
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
