Question about MSI A6000029US Notebook 16 widescreen Intel Core 2 Duo T6600 4GB Memory 320GB HD (816909064230
Need router number
I want to connect a printer. I need to know the router number or what ineed to set up a wireless printer
    Scholar:
  • 51 Answers
First, see if you can access the diagnostics on your wireless router as the administrator, so you can change things if you want. Usually, this is done through a wired connected computer to the router. Most routers have the IP address access of 192.168.0.1 to get in there.
From that point, you want to look for the wireless (WAN) settings for the router, and you may either specify the IP, or make it auto-connect. Either way, make sure you have some sort of wireless encryption security, with a secure password you set-up.
On your printer, you will probably have to specify the router IP, and make sure it auto-connects IP on the printer (unless you prefer to specify it). You'll also need the encryption password to establish the initial connection.
Some newer printers and routers have a button that can be pressed to make connecting them easier. However, you may still want to make sure you have good encryption on your wireless router. Many people make this common mistake, and end up losing a lot of valuable information and unknowingly give out their account numbers, passwords, etc.
Move cautiously with wireless connections, and always make them secure.
Posted on Feb 14, 2012
I just want to set up an internal network with dlink router
To setup a network just follow the step by step guide that came with the DIR-615 router. When it comes to setting up the internet on the router wizard just select Cable or DHCP and leave the other internet settings as default.
As regards to your printer we need to know the make and model number so we could further assist you. By knowing the make and model of the printer it will help us how to best setup your printer on the network. The model number is usually the name of the printer or near barcodes on the back or bottom of the printer.
Dec 17, 2012 | D-Link DIR-615 Wireless Router
I have a Arris TM722 modem and I need to know my SSID number and password? please help me!
An SSID is the name of your wireless network connection and doesn't have to be a number. As I don't believe that this modem supports wireless connectivity, it should not prompt you for an SSID or a password. If the modem is plugged into a wireless router however, and a wireless network has been set up, the SSID will be related to the wireless router.
Generally most devices can scan for the SSID when attempting to connect to a wireless connection. If there is an "automatic" setting or a "find networks" button, you can try that and choose your wireless connection from the list provided. For a password, you may need to ask whomever helped set up your wireless network.
Jun 01, 2011 | Office Equipment & Supplies
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Mar 15, 2011 | Belkin (F5D5231-4) Router
Ineed a key to set up a computer to connect to my linksys wireless router
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Aug 28, 2010 | Linksys Wireless-G WRT54G Router
How do I set up a home wireless network for windows xp?
Do you have any computer connected to the router ?
If not then connect the computer to the router with the cable.
Open the setup page of the router.
Change the name of the network.
Secure the wireless network.
Try to connect to the wireless network on wireless computer.
Once you connect to the network, you will be able to go onl ine.
Aug 14, 2010 | Linksys Wireless-G WRT54G Router
Can I connect my 2wire to my printer to print wireless, if so how?
router
is there any computer connected to the router ?
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
on your printer there will be settings of network connection.
you just need to connect to the wireless network on the printer
Click here to know more about routers
Jan 10, 2010 | 2wire HomePortal 100W (1000-400026-000)...
Ineed to access the router to lock it
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.1.1)
3. Enter the router setup, login and password (default Login = admin
and default PW = admin unless you have already changes it)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | Linksys Wireless-G WRT54G Router
Can't connect my new Brother MFC490CW wireless printer. I do I proceed to activate my printer with this router (SMC2804WBRP-G)
ti is a wireless printer.
You will need to connect to the wireless network on the printer.
you will need to check the wireless settings of the router.
Click Here to know how to check the settings of the router.
Nov 01, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
MSI A6000029US Notebook 16 widescreen Intel Core 2 Duo T6600 4GB Memory 320GB HD (816909064230 Logo
49 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
