Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Stove Code F1-4 (bottom door won't open)
I just cleaned my Maytag Gemini Electric oven. Once the cleaning cycle was completed I got an F1-4 code. The top oven door will open but the bottom oven door won't. Tried to cancel the code but it keeps coming up.
  • 4 more comments
  • rx4thomasl Nov 14, 2008
    same problem- what's the solution?
  • lhumble Nov 22, 2008
    I do have the same problem, just as I am trying to cook family thanksgiving. Help!
  • hamcrab41 Jan 22, 2009
    I had the same F1 code after using the auto cleaning mode. We replaced the keypad and go the same error code when we plugged the appliance back in. What now?
  • Anonymous Mar 22, 2014
    Code went away when the oven door was opened but I was unable to use the keypad at all
  • Anonymous Mar 23, 2014
    Top oven light will not turn off
  • Anonymous Mar 30, 2014
    F1-2 code on maytag gemini oven. Replaced temp sensor already. Could circuit board be bad?
  • 409 Answers
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
How do you adjust bottom oven door one side loose
Posted on Jun 04, 2010
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
1, Controloptionsmay be changedby se-
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
4. PressCANCELpadtosetthe displayed
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
The ovens fail to work after the cleaning cycle - displays says "call service". Now both ovens will not operate and neither do the timers.
Maytag model MER6772BAW was displayying f9-2 and call Authorized
service after cleaning also top door was locked and feature were disabled. I was able to solve the problem by unplugin the stove and waited about ten seconds before re-conecting once up the top door unlocked cleared the f9-2 error by pressing Auto set button and number 9 for Defauts. Perhaps this can help you.
Aug 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Feb 24, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Self cleaning
You can go to the Maytag web site and download the manual., or go to
and download the manual CAUTION
• It is normal for parts of the ovens to become hot during a self-clean cycle.
• To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
• Avoid touching doors, windows or oven vent area during
a clean cycle.
Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
Do not leave baking/pizza stone in the oven during self-clean.
The self-clean cycle uses above-normal cooking temperatures
to automatically clean the oven interior.
The oven should be cleaned regularly by wiping up spillovers
to prevent excessive smoke and flare-ups.  Do not allow a
heavy build-up of soil to accumulate in the oven.
During the cleaning process, the kitchen should be well
ventilated to get rid of normal odors associated with cleaning.
Before Self-Cleaning
1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
cycle.  (The gasket is the seal around the oven door and window.)
4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
• Oven temperature must be below 400° F to program a clean cycle.
Only one oven can be cleaned at a time.
• Both oven doors lock when either oven is being cleaned.
To set Self-Clean:
1. Close the oven door.
2. Press the Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning settings.
     “HVy” (Heavy Soil, 4 hours)
     “MEd” (Medium soil, 3 hours)
     “LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
    • CLEAN will appear in the display.
    • LOCK will flash in the display.  Once the door locks, LOCK will
      remain steady.
    • The cleaning time will start counting down in the display.
Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
743 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
