Do i need special cables to get a good picture on my sanyo flat screen? i ihave dish tv and do not subscribe to hdtv. station receptions appear fuzzy.
  • 128 Answers
Have you tried another tv? if it's still the same you need to realign your dish antenna
Posted on Oct 25, 2008
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
Add a station
This set isn't capable of going over 68, this is all it's programmed for. You will need to get a channel box that overrides the tv's programming in order to add the channel 73.
Aug 27, 2008 | Sanyo DS20930 20" TV
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Digital tv reception
Any developments with the snowy Channel 3?
Good luck and thank you for using FixYa.
Oct 24, 2008 | Televison & Video
Sanyo HDTV 42"
'Clear' can mean different things-
The 'front end' of TV sets can differ greatly in the sensitivity of its tuner.  If you have 'snow,' then the new set is inferior to your previous one and you may need to buy an external broadband amplifier to boost the signal before it goes to the TV. The quality of antenna inputs has declined since there are fewer owners (by percentage) who depend on 'over the air' reception. Cable companies and satellite receivers supply a lot more signal than can your antenna so the input sensitivity is not as critical as it once was.
The demo sets one sees at retailers are fed a lot of signal and have for that reason a better picture than you might find after getting a set home.
Aug 04, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
HD reception
To have HD on cable, you will need an HD cable box with the HD service activated by the cable company. Some cable carriers will provide some basic HD services included in the base cost with the box.
From the HD cable box to the TV, you will need an HDMI cable between the cable box and the TV set. This is an HDTV interconnect wire. You will have to refer to the instructions on the cable box and on the TV to get everything going properly.
Jerry G.
Apr 28, 2008 | Sanyo DP26746 26 in. LCD Television
Re: Sanyo TV Model #: HT27547 Will I have to get a converter box to watch tv stations?? In a few days I will disconnect my satellite service. Thank you!
This link will verify that yours is digital ready.
If not click able go here.
http://reviews.walmart.com/1336/5652233/reviews.htm
to see reviews for your Sanyo flat screen model ht27547
You may have to purchase a new antenna to do that search for one that is specifically for digital reception and good for the distance from station to home. (Range rating)
Apr 25, 2008 | Televison & Video
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
Sound but No Picture
Connect your outdoor antenna directly to your antenna in, in your TV see if it works and do the same with your cable input if it works then the A/B box is at fault.
Oct 28, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
