Question about Toshiba Satellite C655D-S5044 15.6" 2GB RAM 320GB 6 Cell Battery (PSC15U01L010) PC Notebook
The laptop won't boot
I can turn the computer on, but it won't get much farther than the toshiba logo. While it would usually start booting Windows 7, I instead get PXE-MOF: Exiting Intel PXE Rom. No bootable device--insert boot disk and press any key Now, I don't know if this helps much, but I've tried installing Ubuntu from a CD and, while it boots, it cannot install because it cannot find 4.4 gigs of HD space.
    New Friend:
Unless you repartitioned your hard drive before attempting to install ubuntu, i would bet, based on your symptoms, that you damaged your MBR for windows. When the TOSHIBA splash screen is displayed when you first turn on your computer, a boot menu prompt may be displayed for a few seconds near the bottom of the screen, indicating that a key (F2 or F12, for example) can be pressed to display a menu of boot options. you need to look for the prompt for "repair"...hopefully, your backup of windows is not damaged...
Posted on Jul 30, 2017
    Habit-Forming:
    New Friend:
  • 10 Answers
Probably the hard drive in your laptop is gone.
try booting ubuntu in live mode, so without installing it.
when the boot is completed, launch the tool gparted and see if it detects the hard drive: if it doesn't, you need to change the hard disk..
SOURCE: toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Posted on Jun 16, 2008
Geekman
  • 32281 Answers
SOURCE: i have this on my
The hard drive may just need reseating to make it work, failing that the hard drive is either faulty or the had disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and then plug it into a working computer's USB port, if you see this drive as a external drive and can see the contents of the hard drive the it is OK.
If the hard drive isn't recogonized then the hard drive is faulty and you need to get a new hard drive for your laptop and install Windows, the drivers and your programs etc.
Posted on Apr 07, 2009
cirocpatel
  • 524 Answers
SOURCE: Pxe-e61: Media test Failure check
in order to load the Operating system I request you to disable the SATA Native Mode in BIOS and then load the Operating system. 1. Please perform the below steps for the same:
a. Restart your computer.
b. When the F10 setup message appears in the lower left corner of the screen, press the F10 key.
c. Locate ‘System Configuration’ and then select ‘Device Configurations’.
d. Under ‘Device Configurations’, select ‘SATA Native Mode’ and disable the same.
e. Save the settings and exit.
Once the SATA Mode is disabled, please install the Operating System in the normal fashion using the Recovery CDs or the Operating System CDs that you have. Before installing the same, you need have the SATA Controller driver. Please follow the ’Installation Instructions’ in the SATA controller driver link given below.
2. Download the latest “Intel SATA AHCI Controller Driver” driver from the below mentioned link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId
=321957&prodSeriesId=3356620&prodNameId=3356622&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ob-54270-1
Upon installing the same, please get back into the BIOS and enable the SATA Native Mode.
Note: The third-party information provided is to help you find the support you need. This information is subject to change without notice. HP in no way guarantees the accuracy of this third-party information. The software manufacturer will provide support for this software.
Please update your observation for us to serve you better.
I have also given you the link below for the XP Professional Drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId
=3356622&prodTypeId=321957&prodSeriesId=3356620&swLang=13&taskId=135&swEnvOID=1093
The above given information are pertaining to HP 6710b Notebook PC. If you do not have the same, please update the serial number for us to given you more information.
Posted on May 03, 2010
  • 2567 Answers
SOURCE: when i start my lapt
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Posted on Dec 07, 2010
  • 1623 Answers
SOURCE: toshiba c650: chek cable connection!
your hard drive is corrupt or it is broken
Posted on Feb 13, 2011
ASUS laptop stuck at logo
One option is to do a reset to the whole computer but be warned you WILL LOSE ALL YOUR FILES. now if you still want to go on what you will do is when you turn it on hit the F9 key and it will take you to recovery mode are it should
May 04, 2013 | Computers & Internet
How can i exit safe mode on my toshiba laptop
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 02, 2012 | Toshiba Computers & Internet
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
Sep 08, 2012 | Toshiba Satellite L355D-S7813 Notebook
Can't boot computer
Is this condition present on all USB ports? if so the external mouse probably will need to be replaced.
Aug 18, 2012 | Toshiba Computers & Internet
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Laptop wont boot toshiba logo stays on forever
Put Your Restore Cd Or OS Cd in and press and hold F8 to choose to boot to cdrom.. then Repair your OS Start up...
Or try pressing F10 on boot up to go into built-in restore options
Nov 19, 2008 | Toshiba Computers & Internet
Toshiba Satellite C655D-S5044 15.6" 2GB RAM 320GB 6 Cell Battery (PSC15U01L010) PC Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
