Question about Refrigerators
Frigidaire model fgun2642lp0 water filter light wont reset
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Posted on Sep 19, 2009
imufo2
  • 3773 Answers
SOURCE: my frigidaire gallery series model
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 23, 2011
How to reset the order filter feature
Good Afternoon Friend,
I understand that the order filter light is showing on your Frigidaire refrigerator, model# DGHF2360PF, and you want to know how to reset it. What you will need to do is press and hold the Water Filter button on the Ice & Water Dispenser control panel for three seconds. When the display changes from Red to Green, the status has been reset. I hope this is helpful.
-Best regards-
WP
May 15, 2014 | Frigidaire DGHF2360PF Gallery 22.6 Cu. Ft....
Cannot reset the filter light
Hi David, this is AP.
I understand you are having trouble resetting the water filter light on your Frigidaire refrigerator. On this model, FGUB2642L, I would start by pressing and holding the water filter button located at the top of the display panel for 3 seconds if you have not already. If that option does not work I would recommend using the default settings button. Hold down on the button to reset all refrigerator settings. If that still does not rest the light I would suggest cutting power to the refrigerator for a few minutes to reset the display. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 21, 2014 | Frigidaire FGUB2642L
Frigidaire filter status light will not reset
Check to be sure your water source is on. Low pressure may make the filter sensor think there is a plugged filter.
Mar 17, 2014 | Frigidaire Refrigerators
I have the frigidaire refrigerator & I replaced the water filter ,how can I rest the water fliter into green light?
Press and hold the filter reset button on the front of despensor 10-15 seconds until the green red and orange lights come on.
Jun 03, 2011 | Frigidaire FRS26RLECS Side by Side...
How do i replace the water filter.
http://www.frigidaire.com/manuals Enter your model number
Manual link:
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241661500en.pdf
Actual precedure with pictures is on page 14 of the above link.
GENERIC Installation Instructions:
  1. Unscrew the filter cup and dump out the water
  2. Pull the old filter straight down and discard
  3. Place the new filter in the filter cup
  4. The end of the filter with the small o-ring should be up
  5. Screw the filter cup (with filter) up onto the housing
  6. The filter will self-align as the cup is tightened
  7. Reset your 'change filter' light (if your fridge has one)
Resetting your filter change indicator light:
  • Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds)
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Frigidaire Side By Side Refrigerator 26...
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
Oct 02, 2010 | Whirlpool Refrigerators
Where is the reset button for the ice and water after you have changed the filter
On models with a Filter Status or Filter Reset light/button, it is part of the water/ice dispenser panel. The button will be just above the light (usually to the left of the other buttons). Press and hold the button for at least 10-15 seconds until the green, amber and red lights flash.
Other models just use a sticker that should be placed on the front of the filter cup.
I hope this helps.
Aug 22, 2010 | Frigidaire FRS3R5EMB Side by Side...
Sep 17, 2009 | Refrigerators
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
