Loading The screen says loading, but nothing happens will not play disc only says loading and disc spins real fast
  • 1 more comment
  • ragott Dec 07, 2008
    The description is accurate for my problem.
  • adrianalaver Jan 19, 2009
    I put in the DVD disc and it spins for a few seconds saying loaded.  Then it stops and the sceen dispalys No Disc.  What is going on?
  • Anonymous May 19, 2009
    Same problem
    Problem Solver:
  • 14 Answers
This depends on the type of disc player you have, but after you have had a DVD player for a least a year, dust will build on the motherboard or around the laser, most dust is magnetic and will cause different problems like focusing of the laser lens, or the at times when your disk has scrathes and you will hear the laser bounceing tring to read the disc, this will cause a recoil burnout on the laser, also another important thing to no is your CD's and DVD's this is for all types, when you look at the label of the Disc this is where the information is stored, the label sets on a thin piece of plastic, everybody is so worried about scratching the plastic, they make cleaners and buffers for the plastic, its the label you really have to worry about. In other words don't flip your disc upside to lay then down, this can cause more skipps and freezes, another thing is if your DVD player is setting on top of a older TV's this is a problem. The older tubed TV's have magnetic flukes, have you ever wondered why the dust is on the TV, remember I said Dust is magnetic, the two attract
Back to the DVD player or VCR setting on top the TV or beside an older TV, is because of the magnetic flux of turning on the TV and the TV staying on will cause your items like the DVD player, cd player, VCR, will have pull on them, along with knowing this when your cords are all dangling behind the older TV's the type of video cable that hangs behind your TV is effected the same way. Cheaper cables will allow for magnetic flux to be imposed on the cable there for your color will look out of place like your TV picture just went out, this works with sub woofers as well you need to keep at least a 4' to 5' distance from your subwoofer with any cables, DVD, VCR, and CD player. A subwoofer setting next to a TV will cause the picture to "as some call bleed" change the color, never leave a TV setting on top of a subwoofer this will cuase the color to change on your TV as well. If this happens to you unplug the TV from the wall, becarefull and lay the TV on the face down, the picture needs to go against the floor let it set there for at least 12 hours, then set the TV up right and plug it in.
If you've checked all your cables and where your subwoofer is setting then chances are your laser went out on your DVD player. There are other some other problems that can occur as well, but these are about it, the rest should be left up to the TECHs
Posted on Jan 14, 2009
Why won't my cyberhome 320 load
some dvdv players won't read copied dvds
you can only play original dvds
Jun 04, 2014 | Cyberhome Slim Dvd Player W/ Remotecables...
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
Ps3 not reading cd/dvd/games/blurays
hi...
The inside of the disc player is probably dusty. Video game consoles are notorious for gathering dust. I've fixed dozens that way. Cleaning inside the drive
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Jun 09, 2007 | Sony DAV-FR10W System
Televison & Video Logo
413 people viewed this question
Top Televison & Video Experts
Electro Med Services...
