Question about American Pro VS-2043 Car Audio Amplifier
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
My amp.was playing good until one off my bass speakers wire touched something an sparked the green light is stil on put there is no noise going to my mids speakers or my bass speakers am wondering how i can i fix this problem its a american pro vs-2043 1000watts 4ch amplifier i would really appriciate if you could help wit this problem
    Scholar:
  • 148 Answers
Http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
2 Suggested Answers
Jexx
  • 148 Answers
SOURCE: how to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
2004 honda accord radio
An issue I had with my radio was the sound not working. Some wires were touching metal this causes the sound to not work. In addition to this make sure the antenna cable is hooked up!
Jan 24, 2014 | Cars & Trucks
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
Amp is connected to speakers but the volume coming out of the speakers is very very quiet. Speakers have been tested seperately and are known to work. Have turned the input sensitivity to max, this makes...
sounds like you need to turn up your gain and bass. while amp is on and your favourite music playing, turn up the diles on your amp until you get the sound you want one by one.
Feb 28, 2011 | Kenwood KAC-529S Car Audio Amplifier
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Subwoofers unresponsive
Check the physical condition of subwoofer to make sure that the surround has not rotted out or been blown away. If ok, then using an ohm meter check for the nominal speaker voice coil resistance to make sure it is within spec. If both of these areas are good then you have destroyed the output stages of the amp(s) driving them. Every 3 db of bass boost doubles the output power. So if you are blasting along at 100 watts and you jack up bass by just 3 db the amp now has to put out 200 at those lower frequencies; go up by just 6 db and you are now talking 400 watts! And what does that do to an amp when you over drive it? You guessed it!
Aug 27, 2017 | JVC MX-G50 CD Shelf System
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
American Pro VS-2043 Car Audio Amplifier Logo
270 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
