Question about KitchenAid KGRA806PSS Gas Kitchen Range
Kgrc608lss0 looking for the fuse
The burners all light and starters work but control board not working. The oven is out and all lights are not working. Are the boards gone and which one (top or bottom) board or is there a fuse that needs to be replaced? Can you tell me which one is bad or is it the fuse and if so where is it located. Thank you
  • 1 more comment
  • Anonymous Nov 25, 2008
    exactly the same
  • Karpentor Dec 09, 2008
    Burners are working
    Oven is working, however the display does not show anything.
  • deomlid Dec 23, 2008
    Was cooking with the oven the other day. Display went out, oven shut down, 1/2 hour later, display came back and we could use the oven again. Could lite the burners at any time. When the display came back, PF was displayed(power failure)
Kenmore Model 790. Burners work but the electronic buttons and the oven do not work. Is there a fuse for this? None of the display works or lights up.
You will need the control board for your range. I can direct you to the part if you can post the model number off the unit. Look in the oven for it.
Aug 03, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
The digital panel on maytag does not work- can't use oven.
no there is no fuse for that.
the clock board seems to be finnished.
May 27, 2009 | Maytag MER5775Q Electric Kitchen Range
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Oven and lights stopped working
is it the indicator lights at the top or just everything in the oven that is not working??
If it is just the light in the oven and the oven not heating then you are having a problem with your control board.
Jan 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kitchen Aid KGRC608
Hi does this range have a fuse for the circuit/timer board its not on at all but burners still lite and starter works if the is a fuse will you tell me where its at or is the top board fryed or the bottom board yes there is a bottom board on the right sie base in draw area dont know what to change i thought maybe it was only a fuse but can't locate it thanks for your help with this . model kgrc608lss0
Jul 30, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven Control Out - Blown Fuse?
If this is a total gas range then it wouldn't hook up to 240. Check to see if top burners are working. The oven control board only controls the bake/broil. If the bake/broil is the only thing not working and all connections to the board are tight then replace the board.
Oct 04, 2007 | GE Profile Spectra JGBP85 Gas Kitchen...
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
137 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
