Question about Electrical Supplies
Miller swelding 304 pipe pro
Low voltage weak arc
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Miller Pro 350D and the exhaust flex pipe needed
Hi Kyle. Welcome to FixYa. I am Kelly.
You will have to go to this link...
http://www.millerwelds.com/service/ownersmanuals.php
WITH your
Model Number ____________________
AND
Serial Number _____________________
Then download your owners manual (Wildcat 350D I think)
Look up your part number in that manual
And then
http://www.millerwelds.com/wheretobuy/
Enter your postal code.... and that should find your local dealer.
Thanks for using FixYa!
Kelly
Posted on Feb 23, 2010
My miller 175 wire feed does not feed wire at low number settings
Usually, the drive motor voltage is derived from the weld voltage, so if you lose, the weld voltage, the motor will not turn. Feed some wire out in a setting that works, then switch to one that doesn't feed, and see if the wire will arc. If you have a voltmeter, check for DC voltage at the polarity changover. Might be a bad voltage range switch.
Mar 30, 2017 | Miller Welding Tools
Miller 130 wire advances, fan runs, but will not arc as wire comes out
Most of these machines (would have to have serial number to be sure) will not feed if their is no output voltage, since part of the motor voltage comes from the arc voltage.
So, I would suspect broken wires, either in the work lead or the gun. If it arcs just a little, probably the gun. One place the work lead breaks is right at the back of the clamp. Pull on the insulation and see if it "stretches". If so, the wire there is broken.
Feb 21, 2015 | Miller Welding Tools
I plug in my miller 304 cc cv welder, 220 voltage, the numbers flash randomly, wont balance out, wont weld, any solution
What does the voltage window display? If it is reading open circuit voltage then check your leads. You could have a front control board failed if not. You should probably take it to a miller tech to have pre power checks performed.
Feb 15, 2015 | Miller Welding Tools
I have a miller 304 pipe pro and I can not get the voltage or amprage lights to come on the digital display
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 11, 2014 | Televison & Video
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
I just started up a Miller Big 40 welder after 18 years, it runs like a charm, but the 110 plug is dead and there is no arc when trying to weld.
After 18 years, the welder has either lost its residual magnetism (which allows the output voltage to ramp up) or the voltage regulator is defective. Another possibility would be the brushes for the field not contacting the rings like they should - damaged brushes or weak springs. Contact Miller/ Hobart for a service manual, these checks are relatively easy to perform. The manual will give you specs that can be used for go or no go testing.
Aug 21, 2011 | Garden
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Miller dynasty dx 300 that began throwing help code 7, which is too high of voltage. The voltage reads 246 volts coming in to the welder. It keeps blowing diode pack pm2. Any ideas what could be the...
The Voltage refered to is the Arc Voltage not the input voltage, for dip transfer the arc voltage needs to be 18-20v for spray transfer try 25-38volts both depending an the WFS setting. arc voltage is set on the voltage control dial. lets know how this turns out.#
Ken
Feb 01, 2010 | Welding Tools
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
