Question about Proview XL370B (Black) 17 in. Flat Panel LCD Monitor
Preview 700 P
My proview TFT 700P goes to stand by but the indicator remains green.
I tried changing one power capacitor but the problem still remains can u help me. My mail ID is narwal_sunil@yahoo.co.in
sunil
  • 4 Answers
You should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Posted on Nov 21, 2008
My proview 700p has lines and picture jumps can anybody help me please
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 24, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor 700 P proview TFT problem
Try changing out all of the capacitors on the power/inverter board first.
You probably do not have to change the large main one, Just the other ones.
It sounds like you have voltage but your amperage is not there. the 11.7 should probably be closer to 12.
Ebays
bammbammfran
Oct 28, 2008 | Proview PT 15.1" LCD Monitor
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
I have a Proview MA-782KC 17" TFT Monitor and when I switch it on the green power light flashes but nothing is appearing on the screen. When it was working properly the green light remained aon all...
I`ve opened it up and there are several 470uF capacitors in the power circuitry which are obviously bulging, meaning they are in considerable distress. I am ordering some replacements and will fit them when they arrive and see if they get it working. I`ll let you know :)
By the way, I don`t recommend this for anyone not versed in this kind of repair. Messing about inside the power circuit of a monitor can KILL - even unplugged, unless you know what you are doing, so please take care.
Sep 09, 2008 | Computers & Internet
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Proview 700p problem
DISPLAY IS GOING OUT SIMPLY GET NEW MONITOR
Jan 16, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Usually when the power light flashes and the screen remains blank and unlit, your power board is in fact malfunctioning. This is not always the case, as the problem can sometimes reside in the input or inverter boards. I would first recommend that you feel comfortable with opening up your screen and looking at components. It can be a little overwhelming at first. BEFORE PROCEEDING, UNPLUG POWER TO MONITOR. If inclined to check, carefully open the casing around your screen. I have not worked on your particular model, but some are easier to open than others.
Once opened, you need to gain access to the circuit boards. Sometimes they are not protected by metal, other times they are completely encompassed. The flashing power light usually indicates that a capacitor(s) is(are) malfunctioning. To see if this is the issue, locate the power board (usually the one with larger-size components) and look for any capacitors having bubbled or raised tops and/or oozing a brownish liquid. If not on the power board, look elsewhere for the same symptom.
PLEASE BE CAREFUL!!! If you have recently had your monitor plugged in, the larger capacitors can still carry a charge. If you cross the leads of a capacitor while it carries a charge, it will discharge. It won't hurt any other components, but if you cross the leads with something that is in direct contact with yourself, you can get quite a jolt! There is usually a large voltage capacitor (normally just one) on the power board of these screens. I tested one with a multimeter after immediately unplugging it, and it still held a 166V charge! So please, do this with caution.
If a bad capacitor has been found, simply remove the old one and solder a new one in its place!
Nov 26, 2007 | Computers & Internet
Proview XL370B (Black) 17 in. Flat Panel LCD Monitor Logo
420 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
