Question about Ovens
My parents have side by side thermador ovens wo-16a that don't heat very well looking for a repairman
SOURCE: old thermador 1950s wall oven, will not turn
Did you find a solution to this? I have the same problem.
My email ...tgl@hotmail.com
Posted on Jan 05, 2010
fixyourboard
  • 310 Answers
SOURCE: thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
ginko
  • 19396 Answers
SOURCE: Thermador Built in oven scd302 not heating upper
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
Posted on May 31, 2011
taran_2005
  • 10515 Answers
SOURCE: Thermador oven beeper continues to beep. won't
Do you see any error message on the screen while the oven is beeping?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2011
  • 9 Answers
SOURCE: My Kenmore Electric Range model 790.9661 seems to
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Posted on Jun 11, 2011
Thermadore WO-16A electric oven but the thermocouple has gone out.does anyone know of a replacement part?or at least part #?
I believe you mean a thermostat. Contact a distributor such as Automatic Appliance Parts at 800.323.0270
Nov 15, 2014 | Thermador Ovens
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Thermador oven won't heat up
Hello, welcome to FixYa.
I'll start by saying, I just received an email saying you were asking me a direct question...I will tell you what I know based on my experience with Thermador (extensive) and the description of your post. This sounds like a possible hi-limit thermostat tripped scenario.
I don't know if you know where it is or how to check it, or if this is the case with both upper & lower ovens...but they are independent of each other on the SC302T, so if you can reply and elaborate I'll b glad to help in any manner I can. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Sep 29, 2011 | Thermador SC302T Electric Double Oven
I need a replacement selector switch for an electric oven. It it for an old Thermador electric oven (one cavity type wall oven). Model number: WO-18A
Hello & Welcome to FixYa
You can buy it from here. Please get back to me if you have any other questions.
Kevin
Sep 13, 2011 | Thermador Ovens
After I cleaned my ovens the top one doesn't heat anymore. I was told that the circuit fuse button has to be reset. We can't locate it. Can you please help? The model umber is: Thermador SCD302TP
Welcome to FixYa.
To address your post, looking for an over-temp cut-out tripped. Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door ( just below upper door) next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Hope that answers your question and gets you back up and operating. Good luck.
Regards,
Macmarkus :)
May 29, 2011 | Thermador SC302T Electric Double Oven
Oven will not heat up broiler works. its a thermador rdss oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
