Question about Pioneer VSX-403 Receiver
Surround not working
Speaker center fail
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
My L/R surround speakers and my center speaker are not working. My Front speakers and my Subwoofer are working. When I plug in my L/R surround & Center speakers into, say, my front speaker ports the...
in most cases it is becaues there isnt a 5.1 channels be broad casted you have to use either an digital in or hdmi cable just ask some one at the store
May 12, 2010 | Sony DAV-DX255 System
Surround Speakers will not work
Perhaps you have the live wire in the wrong connector from the speakers? They should be color coded. I would check that first. And if you have moved, they are most likely in different positions, you'll have to rerun the audio setup for the surround sound. You should have a separate microphone to use for that that plugs in to the system.
Aug 31, 2009 | Onkyo HTR500 Receiver
Center channel is not working . Surround sound from center channel not working. I have found two fuses blown and replaced . when unit turned back on o try they blew again
First make sure the centre speaker is not shorted, try a different speaker and new fuses. If this fails and you have electronics knowledge here is the link to the service manual...
http://www.enusbaum.com/blog/tag/service-manual/
The driver or power output device (FET or Transistor) is probably shorted if the speaker is not shorted.
Jun 10, 2009 | Harman Kardon AVR 135 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Sep 09, 2007 | Audio Players & Recorders
15 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
