Question about OEM Systems Car Audio & Video
E240 merc 6 cd cartridge does not eject
I have a A002 820 7898 model 6 cd stacker, does not eject the cd cassette
SOURCE: clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Posted on Apr 17, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: 1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Posted on Jun 27, 2009
SOURCE: JBL 6 CD AM/FM Cassette Audio has CDs stuck inside
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Posted on Aug 17, 2009
SOURCE: Peugeot 307
having same problem. faulty after disconection of battery
Posted on Oct 22, 2009
SOURCE: altezza cd stacker error 3 with 6 cd's jammed
i have the same problem if anyone can help please
Posted on Aug 03, 2010
'03 Honda Accord 6 disk changer won't load/eject
i had the very same problem with a six stacker in my ford, the stacker inside has come of its tracks even by one or two teeth so when the cd tries to eject it jams on the side walls because of this alignment, only way to fix is to take it out and realign. may need to get a mechanic or your dealer to do it like i did as the computer system was attached to my cd player. not sure about the accord but this is a familiar problem with all sorts of 6 and 10 stacker cd players
Jun 23, 2010 | Car Audio & Video
Jammed cd in cd player with is a inbulit 6 stacker cd player that came standard with my car
if you can not eject cartridge
PRESS AND HOLD EJECT BUTTON
Insert credit card or similar under cartridge push fully in and move under cartridge,this will locate micro switch and eject
Then you can check discs
Jun 06, 2010 | 2003 Mazda Mazda6
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
The cd changer won't eject any cd's - shows "CD error". How can I get it to eject? Also - the cigarette lighter in the center console does not work so I can't use my charger. I know there is another on the...
If you have a stacker /changer
Insert credit card or similar firmly under cartridge
Push fully in and move left/ right.
This will locate micro switch and release cartridge
Dec 26, 2009 | 2003 Ford Expedition
Pioneer CDX-P670 Wiring / Power
hi according to the manual the two pin connector is for the power and the pin nearest the square control plug is ground, the other pin is +12, have tried this with mine and it works
Nov 26, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
How do I remove the 6 stacker CD player from the Dash board of my 2005 Hyundi Sonata. There are 6 discs stuck in it and it won't play. The radio works so it is not an electical problem to the unit
If it has a 6 cd cartridge, try this.Press and HOLD eject button, insert credit card under cartridge move left to right to locate micro switch which will release cartridge so then you can see if one of the discs has jammed.good luck.
Nov 08, 2009 | 2006 Hyundai Sonata
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Jul 31, 2009 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
Car Audio & Video Logo
16 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
