Question about Toshiba Satellite A135-S4527 Notebook
My laptop button 3,E and D not responding
Whenever i press button 3 orE or D ,not displaying
  • 36 Answers
Your best bet is to get a can of air duster and blow out any debris that my be in your key board. if that does not work you definitely need to take it to a professional shop. good luck
Posted on Oct 29, 2008
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Touch Panel Adjustment
Functions • To adjust the position of the Touch Panel display
Use
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
Adjustment
Procedure
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
I have the NEC versa E6200. Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding. What should I do??
Have you run a Virus scan and a malware scan? when you say" Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding" whenever I use it means what just moving the cursor or going online, opening a program etc. could you be a bit more specific that would help in the diagnosis.
Oct 31, 2012 | Computers & Internet
How to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Aug 20, 2012 | 7752V Replacement Transmitter Supercode...
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
How do I get a confirmation when a fax is sent
Press FUNCTION and DATA REGISTRATION.
Use the search buttons(^,v) to display 3. REPORT SETTINGS.
Press SET, then use the search buttons to display "TX REPORT"
Press SET, then use the search buttons to select "OUTPUT YES"
Press SET.
now exit from menu and whenever you send a fax a trasmission report will be generate automatically
Jan 06, 2011 | Canon CFX-L4000 Plain Paper Laser Fax
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
My hp printer 5610 all-in-one does not turn on. What to do?
whenever i press the 'on' button, my printer doesn't respond.
Jan 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Toshiba Satellite A135-S4527 Notebook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
