Question about Exercise & Fitness
I own a Gold's Gym 450 Treadmill. The other day I was about to use it and so I put it on incline (to the highest level) and somehow I pushed the stop button and instead of stopping it started acti
It's a Gold's Gym 450 Treadmill
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
SOURCE: Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: my smoothfitness 5.25 treadmill is stuck in the
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
Posted on Mar 11, 2010
  • 34 Answers
SOURCE: my treadmill is stuck at the highest incline and
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Posted on Aug 18, 2010
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
Treadmill incline not working
The incline system may need to be calibrated. To initiate the calibration routine follow the steps below.
Step 1
Place the key into the machine. The key's slot is located on the bottom of the console, below the start and stop buttons.
Step 2
Press any of the incline buttons and then remove the key from the machine while the incline is changing. Pause for a few seconds and then put the key back into the slot.
Step 3
Wait as the treadmill automatically shifts to the highest possible incline and then descends to the lowest level. The treadmill should now be recalibrated.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
I have a Gold's Gym trainer 410 treadmill. I
please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover for motor, and see the instruction and follow the instruction
God bless you
Jul 20, 2013 | Exercise & Fitness
How to bypass magnetic key on gold gym 450 treadmill
If you need to purchase a new safety key that was designed to work with your Gold's Gym machine, here is a link to one that is listed for seven models of the 450. But please make sure that your exact model is listed to ensure compatibility.
Safety key 6043675 Fitness and Exercise Equipment Repair Parts
Nov 04, 2012 | Golds Gym 450 Treadmill Drive Motor
My Golds Gym trainer 480 treadmill wont start and none of the buttons work except for the up and down arrows for the incline.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
Oct 20, 2012 | Exercise & Fitness
Is there an online repair manual for the Golds Gym Advantage Treadmill? I'm trying to solve an incline problem. The incline does not go up when I push the incline button. I just get a series of beeps...
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Mar 01, 2011 | Exercise & Fitness
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
557 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
