Question about Pool & Spa
Auger not working on Blaze King Pellet Stove
Can anyone help? Our Blaze King is around 20 years old. My FIL purchased it new and owing to failing health did not use it for a long time. My Wife and I acquired the house from his Estate and had the chimney swept. The stove was cleaned and lit. It worked satisfactorily for several occasions but the Auger does not seem to operate and therefore does not supply fuel to the burner. Any ideas? Thanks
  • 239 Answers
Depending on how the manufacturer set up the system, there may be pellets wedging the auger. most augers are geared low enough to snap the pellet but if its something else blocking it (stick or rock etc) it may have blown a fuse for the auger drive or the drive mechanism itself. if you are going to work on the auger. UNPLUG THE STOVE AND USE TOOLS TO CLEAR BLOCKAGE as there may still be some pressure to spin auger
Posted on Aug 12, 2017
3 Suggested Answers
  • 1723 Answers
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Posted on Jul 01, 2009
  • 1723 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ... > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Forums Home > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Heard a bang auger stopped moving seems loose. What's wrong?
Could be a broken safety drive pit in the auger if there is one. I am not sure but just an idea.
Dec 31, 2015 | Us Stove Company US Stove King Pellet...
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' ... > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
We have an Envirofire pellet stove. The auger won't shut off and we can't control the the speed. We had to unplug it. Any thoughts?
You didn't mention which model Envirofire Pellet Stove you have, but generally they all have a heat overload switch, which stops the auger from feeding pellets if the stove gets to hot. They may be faulty. Or The Auger Timing Control Module may have failed. Depending on the age of the stove the gasket material around the door may need replacing. If it's not a tight fit, it's sucking air into the stove and causing it to run more than it should. Normally, I would say, "If all else fails, contact their Technical Service Dept." But, apparently they don't want the consumer contacting them, as there is no contact info on their website. Nor, is there any contact info on the manufacturer's website, Sherwood Industries. "Any technical service questions should be directed to your local dealer."
Hope this helped to get you headed in the right direction in solving the problem.
Mar 13, 2011 | Heating & Cooling
Auger on pellet stove doesn't turn
Jul 08, 2009 | Napoleon Auburn Pellet Stove Heater
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
My pellet stove will start but the auger will not drop pellets. What should I do.
You need to replace the auger motor. Go to fasco .com they may have one. Or I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Nov 20, 2008 | Kitchen Ranges
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Pool & Spa Logo
152 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
