Want to know motherboard pin outs for acer veriton 3700gx
sandrew
  • 2961 Answers
SOURCE: Acer Veriton 5500 Desk top
You will have to find out the make of motherboard in your system to find out the wiring first.
Posted on Mar 08, 2007
  • 349 Answers
SOURCE: Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Posted on Feb 20, 2008
  • 736 Answers
SOURCE: Hi, can someone put up a picture of the pinouts
here is a site where you can download the user guide and manual ... i think the user guide will have what you need for the 3700gx
http://www.retrevo.com/support/Acer-3700GX-Desktops-manual/id/843ag308/t/2/
Posted on Oct 01, 2009
SOURCE: Chases open
if the system continues to show this error after the case has been closed correctly, then check the connection inside the case.....if good then enter bios at startup and turn the feature off and the message will stop.
Please rate this post
Posted on Oct 05, 2009
  • 2666 Answers
SOURCE: i need a sound driver for acer veriton 3700gx
Didn't look very hard did you?
http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1g.c2att92=122&ctx1.att21k=1&CRC=2980211862
Posted on Mar 27, 2010
Power front panel conectors on acer 915m08
This Foxconn 915M08-G-8KS motherboard made for Acer Veriton desktop computers?
http://www.sella.co.nz/general/computers/components/motherboards/other-motherboards/b1jnj6/
Do not know what the Front Panel header pinout is.
(Front plastic part of computer tower is the Front Panel.
Area of contact pins on the motherboard, that the wires (Cables) from the Front Panel connect to, is the Front Panel header )
CAN see by clicking on - View full size image - that the Front Panel header is to the Top Left corner of the motherboard, by the CMOS battery.
(View of mobo is upside down, in relation to how it actually sits in the computer tower case)
Shows me it is just the normal two rows of contact pins used in a LOT of desktop computer mobo's. (MOtherBOard)
If it were I, I would use one of the LED lights connected to two wires, and touch across each two sets of pins.
Looking at the motherboard as it sits in the computer case, there is a row of pins on Top, and a row of pins on Bottom.
In your mind start at the LEFT side of the pins at the TOP.
Number them from Left to Right.
Example, Pins 1, 3, 5, 7, and 9.
Now number the pins on the Bottom, from Left to Right,
Pins 2, 4, 6, 8, and 10.
Computer plugged into power, touch the two wires of the LED light, to Pins 1 and 2.
Computer doesn't start? (Power Supply turns on)
Go to the next set of pins.
I am willing to bet Pins 5 and 6 turn the Power Supply on.
No? Keep experimenting.
What will happen if you touch the WRONG pins?
N-O-T-H-I-N-G
You will NOT hurt the motherboard.
When you get to the correct pins, the Power Supply will turn on.
These pins are for the Power On switch.
Now go back through the pins with the Power Supply on, but DO NOT touch the pins that turned the Power Supply on.
When the LED light STAYS on, you have the pins for the Power On LED light.
If the LED light BLINKS, you have the HarDDrive activity LED light.
If Windows starts to load, and you touch the Restart switch pins, the computer will restart over again, and Windows will load again.
(IF this computer has a Restart switch. I do NOT use one, even for the older computers. Just press CTRL, ALT, and DELete keys at the SAME TIME, to restart the computer, or use the Task Manager option)
One pin left all by itself? That is for 5 Volts, and only used by the factory. Leave it unconnected.
There may also be a blank spot on the Front Panel header, where it looks like a pin is missing. This is the KEY pin, and is not used.
It is just to orient where the other pins are.
Worried about getting shocked?
There may be a small spark, as you connect the wires, I will gramnt you that.
But the voltage is 5 VOLTS DC.
In comparison two D cell flashlight batteries produce 3 VOLTS DC.
The harmful AC voltage is contained in the metal enclosure, of the Power Supply. Can't get you unless you pour water on it close up, or stick a metal rod through one of the ventilation holes, in the Power Supply enclosure.
Regards,
joecoolvette
By the by. You could be a lot of people's hero, if you came back, and posted the pins for what they do. Post in a Comment.
Jun 08, 2012 | Acer MB.V1509.002 VERITON 7700G VT7700G...
Plz send me acer veriton 3700gx sound driver
Since the Veriton 3900gx does not have any special hardware, you could use the standard Windows drivers.
If you want to try something else, try the drivers from an earlier veriton model. http://support.acer-euro.com/drivers/downloads.html
Apr 28, 2011 | Computers & Internet
Theirs no indication where about to put the power switch,power led,reset switch and HDD led in motherboard acer veriton 3600g?
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Apr 09, 2010 | Acer Veriton 3600 (V3600GT00150) PC...
I need a sound driver for acer veriton 3700gx please, i installed windows xp home and now the sound doesnt work and i cant find a download free for the driver
Mar 27, 2010 | Acer Veriton FP2 PC Desktop
Chases open
Oct 05, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Acer Veriton 5600g Motherboard FP1 Pinouts
well only that in most manuals further on in, it should show the pin out you require.,
Terry
Mar 11, 2008 | Intel Motherboard
good luck
terry
Feb 20, 2008 | Acer Veriton 5600G PC Desktop
driver acer sound veriton 5500
Mar 08, 2007 | Acer Veriton 5500 PC Desktop
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
