Question about Pentax Optio S50 Digital Camera
Memory card error
I cleared my picts off card via usb, wnet to use camera & read "memory card error". So, I tried to re-format, & camera ties to format but message comes back "card not formatted". I then went & bought a new sd card & the camera is still coming up with same messages. What's the problem? I also had some fogging of the lens this past winter, while taking outdoor picts (20 degrees temp), could that be contributing to this problem??
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Error message asking for chip to be formatted but will loose all pix if I do How can I save all my pix if I try to download it gives me there is nothing on memory card
    Try reading the card on a computer via USB card reader,if that works download the pictures and then format the card.
    Nov 21, 2016 | Pix Cameras
    When putting the memory card into the slot, the screen reads 'memory card error'. Also, will not read the camera when plugged into USB socket. Please Help!
    The camera port only supports USB-equipped digital cameras that support Pict-Bridge. If you attach a USB device that is not compactible digital camera (or Bluetooth adaptor) to the camera port, an error message appears on the color graphics display. If you have an older HP-brand digital camera, try using the USB that came with the camera. PLug it into the USB port on the back of the HP-all-in-one and not into the camera port near the memory card slots, This works with HP digital cameras only.
    By default, Windows XP will format a memory card of 8 MB or less and 64 MB more with the FAT32 format, Digital cameras and other devices use the FAT (FAT 16 or FAT 12) format and cannot operate with a FAT32 formatted card. Either format your memory card in your camera or select FAT format to format your memory card in a Windows XP PC.
    Hope this helps.
    Thanks.
    Have a good day.
    Nov 30, 2009 | HP Photosmart 2610 All-In-One InkJet...
    I am using a LEXAR memory card. I formatted it on
    Are you using the camera connected to the computer via usb cord? Try using a separate card reader instead.
    Nov 25, 2009 | Canon PowerShot A410 Digital Camera
    PNY SD 2GB card suddenly stopped working
    In the menu of your camera you should be able to format your card. Make sure the little tab on your card is not in the protect position.
    Aug 23, 2009 | PNY 4GB Secure Digital High Capacity...
    SD card - memeory card parameter error
    Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
    Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
    Fujifilm 2gb xd card - shows card error
    pls format the card in Camera thru menu options u will see FORMAT option use it and then check otherwise , first format it on PC and choose FAT16 to format the card and then format one more time on the camera it will work definately
    May 18, 2009 | Fuji FinePix A600 Digital Camera
    Canon A560 will not erase pictures
    Two possible solutions.
    1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
    2. Connect to PC
    Access drive via windows explorer
    Right click on drive (MEMORY CARD)
    Select properties
    Confirm that RO (Read Only) is not selected.
    Selected RO
    Try reading card
    Repeat properties un-select RO
    Try deleting files
    If not successful card is likely defective
    Hope this helps?
    Mar 12, 2017 | Canon PowerShot A560 Digital Camera
    Problem import picts via sd cardreader (taken with eos 450d)
    Some card readers struggle with high capacity (SD-HC) cards and indeed some older devices.
    If you (or a friend) has a lower capacity card (less than 2GB) try that in you camera and then pc.
    You can purchase a VERY cheap USB card reader (c.£10 max) and it should sort your problem - I hope!
    Jan 05, 2009 | Canon EOS 450D Digital Camera
    Memory card error - E50
    Try formatting the memory card via a card reader connected to your PC. Use FAT32.
    May 24, 2008 | Canon PowerShot A75 Digital Camera
    Pentax Optio S50 Digital Camera Logo
    52 people viewed this question
    Top Pentax Cameras Experts
    Geoff Hone
    Jerry Greenberg
    Jerry Greenberg
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
