Question about Haurex Watches
How do i adjust a womens haurex watch band
Adjusting the band
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
The schlatter.org solution is for the other type of casio band I've run into.
The wristband with the arrows has a fine pictorial solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band
Basically you use a very very fine poker to poke the pins out in the direction of the arrows.
NOTE: you can't poke them out if you will drive them into your work surface, so think about that before you start.
Posted on Feb 02, 2008
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
Cannot push pins through women's watch clasp to resize. Help?
you dont take pins out of mesh watch bands all you do is put a dart or small screwdriver in the slot to unclamp it slide the clasp were you wont it then lock it in one of the groovs, click link below for instructions please rate me if helped
http://mondainewatch.co.uk/how-do-i-adjust-a-mesh-strap.html
Jan 25, 2013 | Watches
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
I want to ask whether it is possible for this model GUESS WOMEN'S WATCH W14033L3 PYTHON GREEN LEATHER MUSE to order through which site this same leather bracelet, because I already have this model of a...
Beautiful watch. Very classy. Easy to adjust band with two links that can be removed from the bracket. Large round face with easy to read dial. The bracket construction is especially unique with the two different types of finish. GUESS Women Stainless Steel Leather Casual Watch Color Red Model U0627L5
Feb 12, 2018 | Watches
How do you adjust the expansion band on the Citizen EW0700-98A watch?
these are hard to do. it needs to bend the tabs and pull out staples,then remove links and bend back, these are a pain in the ****. can be done by experanced guy. i can do them 10-15 dollars
Jun 17, 2011 | Citizen Expansion Band Eco Drive EW0702...
I have the Haurex Italy Promise Women's Crystal Watch. I bought it in June of this year. The watch stopped running today. This may not be relevant but I do not wear a watch very often, keeping it more...
It is unusual for a quartz watch to stop so soon (presumably the battery is now dead?).
I suggest you contact the makers local customer care center and discuss it with them.
You can find their local service center by going to http://www.haurex.com/collezione.asp?id=93 and clicking on "after sales service". If you have any proof of purchase date, then it should be still under warranty if it needs repair.
Dec 16, 2010 | Haurex Watches
I need to know how to put on a Haurex watch using it's intricate band
pull the small loop on the end of the metal clasp. place the other strap through the loop and snap closed. fold one end of the clasp shut then the other.
Aug 07, 2010 | Haurex Italy San Marco Chronograph Watch...
How to adjust a metal watch band Fossil Casual Metal Dial AM3861 Watch for Women
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Jun 18, 2010 | Fossil Casual Metal Dial AM3861 Watch for...
I just bought a Haurex watch with the white rubber band and I can not get the clasp to work.
Go back to the supplier; If you cannot get the clasp to work, you should be shown how to operate it (or it should be replaced if it is broken).
Dec 31, 2009 | Haurex Italy San Marco Chronograph Watch...
Watches Logo
55 people viewed this question
Top Haurex Watches Experts
Oloyede Monsuru
ray gallant
Are you a Haurex Watch Expert? Answer questions, earn points and help others
