Question about Frigidaire Dishwashers
Frigidaire pld4555rfc2 dishwasher
Power failure
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: Model PLD4555RFC2 dishwasher stopped running.
to check this you would take off the lower kick panel and go down the bottom of the machine where the power wire plugs into your machine and first assure that power is going to the machine. if you do have power going to the machine yet the touchpad has no power going to it from the control to the touch pad on some units the control is built in with the touchpad then you would replace the control this is the part number for the touch pad 154639206 and here is a schematic of how the control is removed as well click this link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0803230-00001.png and here is also the schematic for your entire machine as well http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-PLD4555RFC2/1428/0130000?pathTaken=&prst=0&shdMod=PLD4555RFC2 i would also suggest to use www.marcone.com under contact us they have a 1800 number and they are much cheaper then sears and other parts suppliers when it comes to prices on repair parts if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks for using Fixya
Rick
Posted on Mar 22, 2011
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
Fixing a Frigidaire Dishwasher (FMB33ORGCO)
Hello Paulus!
From what you have described your Frigidaire dishwasher is will not start and you have performed a reset. This could be a possible issue within your control panel or wiring harness. Since it could be an issue within the electric components I would suggest you speak with a professional technician, they would have the appropriate tools needed for proper disassembly of your dishwasher. Hopefully this is helpful. -Matt
Nov 29, 2015 | Frigidaire 18 Inch Dishwasher White ,...
Power failure light is being displayed on my dishwasher
I appreciate your inquiry, Bernadette Beharry!
From the information you have provided your Frigidaire dishwasher is displaying a power failure on the control panel. This could be a possible problem with your power source, control panel, or wiring issue. I understand that you have reviewed your power outlet. You may need to perform a reset on your dishwasher and to do that you can flip your household circuit breaker in the off position for roughly ten minutes. If the power source is fine and the reset does not correct the issue you may need to have a professional come out and repair your dishwasher. This will help to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Feb 15, 2015 | Frigidaire Dishwashers
Power failure
  • Find the "Start/Cancel" button on the dishwasher's control pad. This button is located on the far-right side of the pad on most Frigidaire Gallery dishwasher models.
  • 3 Press the "Start/Cancel" button to clear the "PF" error code. Resume using the dishwasher as normal. You may have to reselect and start your cycle from the beginning.
Dec 02, 2013 | Frigidaire FDB520RH Builtin Dishwasher
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
Just installed a frigidaire dishwasher and it shows a pf code , how do i fix this ? .
check the power and make sure its wired up correctly pf power failure.
Dec 17, 2010 | Frigidaire Dishwashers
Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
May 27, 2009 | Frigidaire Dishwashers
Run few seconds then quits flashing 3 green lights
If all 3 are flashing it means there was a power failure. Check your power connection to make sure when the washer is coming on it is not knocking them loose.
Nov 26, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
