Question about Tiny Computers Computers & Internet
Hidden xp that is on hard drive
I have a friends time computer which needs reimaging it didnt come with that manual but they say its hidden on the system
  • haytcheff Oct 25, 2008
    do you know whereabouts .... because failing that ill need to get a xp disc for reimaging
  • 47 Answers
Happy to help but did't understand ur problem .plz be elaborate.
Posted on Oct 25, 2008
  • pushpdeep singh
    pushpdeep singh Oct 26, 2008
    if u just install microsoft office there is a program in it called the microsoft office picture manager. and u can do reimagining of ur pictures there. pleasure helping u .
To Whom it may concern: MY GOAL IS TO BLOW AWAY THE ENTIRE DELL VOSTRO 1000 INTERNAL DISK AND REIMAGE USING ORIGINAL CD'S SENT WITH ORIGINAL PURCHASE. BACKGROUND: Wife's PC was running slow and I...
Start the computer.
Select the "old" system, and then repeatedly press F8,
until you see the Windows Start-Up Menu (white text over a black background).
Choose Start In Safe Mode with Command Prompt.
At the command-prompt, enter 'FORMAT C:' to "wipe" 100% of the files from the disk-drive.
When it completes, turn the computer off.
Turn the computer on, and boot from those original "System Restore" CDs.
It will load Windows onto your now-empty disk-drive.
Oct 24, 2010 | Computers & Internet
I am unable to find a location to download the driver for this Hitachi SATA drive. My WinXP install will not work without it. The hard drive is on the computer I am trying to reimage. All the driver...
OK simply get yourself a XP SP2 Install DVD this doesn't require SATA drivers, and will install on any drive at all. If the drive is already formatted and has an operating system, you should not need a driver either? If you cannot address the drive it is probably damaged in such a way, that it cannot be mounted.
Mar 04, 2010 | Computers & Internet
Ibm t-43 laptop cannot find hard drive even though there is one and hard drive was reimaged successfully. rebooted laptop and keep getting error message
Make sure harddrive is set for CS check jumper on drive, Make sure no pins are bent on hard drive, Stop the computer at the bios setup and check the bios is set right..If all this fails you could have an motherboard issue, since you have mention that "the drive has been reimaged"
Feb 24, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
DELL DIMENSION 2400 ERROR STOP: 0x00000024, (0x00100203,0X82F898
You seem to have an error in the boot sequence of the Operating system. If you are unable to access the safte mode of the OS, then you will have to do a hard boot (boot from disk). My suggestion is seeing that you have a Dell, many times they will give you a boot disk or charge you $10 for one to be sent to you. Boot disks are not expensive at all.
Once you recieve the boot disk, go into the BIOS and change the boot sequence that it boots from your CD/DVD drive first instead of your hard drive (C). Then restart the computer with the disk in the disk drive and it will load from the disk.
If that does not work, you will have to do a reimage. For that you will need a Windows OS CD (XP, Vista - whatever OS you use). From there you can either have your data slaved over to another drive prior to reimaging, or if you dont mind loosing the data, just push in the Windows OS CD and it will ask if you want to over write or reimage, answer yes, and it will begin to wipe your computer and place a brand new copy of the OS on there.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Computer may or may not start up. When it does, it may or may ..
Go with a known good working hard drive, its the easiest thing to replace and instead of reimaging it, install windows from scratch and then load the drivers for whatever it doesnt find and then see how it runs, if the lockups stop happeneing then load the apps that you want and everything should be okay.
Jun 26, 2009 | HP Computers & Internet
Acer boots from xp
take it back to store. basically a hidden, but unremovable partition is causing the xp bootup. It happened to me aswell. They will probably give you a replacement as it is an unfixable problem. Even with new hard drive didnt fix it. Sorry about that.
Mar 05, 2009 | Acer Aspire 6920 Notebook PC
Sudden Hard Drive stop
Your hard drive may be intermittenly faulty, any abnormal sounds from a hard drive is not good. I would connect your hard drive to an USB adapter and plug it into a working computer's USB port and do a Disk cleanup and defrag, if possible run disk diagnostic program on the hard drive. If the hard drive proved OK then you may have a faulty IDE controller or faulty IDE cable, check the BIOS battery voltage, may need a new one.
Dec 02, 2008 | VIA (CX-VT6421A) (CX-VT6421A) IDE...
Motherboard issues
Dear, friend
When connecting IDE devices in your computer, there are a few rules you need to know about.
First, Master and Slave devices are different for the 80-wire cables and the 40-wire cables.
Inside your computer, you generally have two (2) IDE hard drive controller connections. They look this this 99% of the time:
[ The smaller one on the very top is a floppy drive controller connection )
Jul 01, 2008 | Computers & Internet
Untitled
I'm guessing you are using a Mac, so you will need a friend's computer with Windows XP or later. Go here for the U3 Launchpad Removal Tool, or Google 'sandisk u3 removal'. The CD image is a hidden partition used by the U3 LaunchPad.
Nov 27, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Unaccessible Drive
I have seen this before and the result was becuase the encryption was activated on the device (a password set) and then the software was lost of the PC - in your case due to the reimaging. Manual installation of the software is required. It is available from: http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Aug 11, 2007 | Maxtor OneTouch III Mini Edition (R01E100)...
Computers & Internet Logo
22 people viewed this question
Top Tiny Computers Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
