Question about Amana Dryers
My amana (electric) dryer NED5100TQ0 will not heat
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
danromarris
  • 101 Answers
SOURCE: My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
dragonsthatk
  • 547 Answers
SOURCE: Amana dryer doesnt heat up
no heat. heat element
Posted on Feb 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: older amana electric dryer model #le8457w, wont heat up
You probably have a bad heating element. This is just about the easiest dryer to repair ever. Take the screws off the base and pull the front off. The heater is on the left on bottom and has all the fuses mounted on it. 2 screws hold the whole thing on. get it out and give it a look over for a bad coil. Not sure if it is bad? Take it to the appliance parts store and let them guys confirm if it has a problem. they will be glad to do so because they hate to have to give refunds on electrical stuff and they know the cust will get bent outta shape. Trust me. How do I know? Because my friend I used to own and operate an appliance parts store.
Posted on Apr 10, 2009
  • 1214 Answers
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Posted on Dec 11, 2009
Amana electric dryer NED5100TQ0 SHUTS OFF ATER 5-10 MINTES.
check the vent system,most common cause of motor over heat-shut down.if motor makes a loud noise at start up, motor is likey bad.
Mar 15, 2014 | Dryers
My Amana elerctric dryer does not heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 08, 2011 | Amana ALE230RAW Electric Dryer
Amana 7200 dryer, runs but has no while running.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Amana NED7200TW Electric Dryer
Amana dryer, no heat, drum turns, timer not advancing
heatman101
Dec 13, 2010 | Amana DLE330RAW Electric Dryer
Model NED5100TQ0 WAS WORKING THEN WE PUT ANOTHER LOAD IN IT AND NOW IT WILL NOT START CHECKED THE BREAKERS AND THEY ARE FINE WHAT ELSE CAN IT BE IT IS ONLY 2 YRS OLD THANKS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 09, 2010 | Amana Dryers
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
My Amana Electric Dryer DLE330RAW not heating
heatman101
Aug 31, 2010 | Amana DLE330RAW Electric Dryer
Replace electric heat element in Amana dryer
Dec 11, 2009 | Amana ALE643RB Electric Dryer
My AMANA electric drier will not heat
Verify 220 volts to the terminal block where the cord connects.
If 220 is there, unplug the dryer and check the thermal fuse and hi-limit thermostats on the dryer cannister.
Feb 22, 2009 | Amana NDE2335AY Electric Dryer
Dryers Logo
46 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
