Question about RCA P61927 61" Rear Projection Television
Rp40tv panel locked
  • h20etj Oct 25, 2008
    i have a rp40tv, i do not have a control and somehow managed to put the panel lock on, i am now unable to turn the tv on. i have tried a universal control..urc22b... but nothing is happening even though i have put the bush code in which is 022, can somebody please help. thanks
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
CHILDLOCK WONT SWITCH OFF ON BOSCH OVEN
Aug 05, 2014 | Bosch Ovens
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
How to remove child lock
  • Press "Menu" on the remote control.
  • Press the down or up arrows to scroll to the "Setup" option.
  • Press "+."
  • Press the up or down arrows to highlight "Panel Lock."
  • Press the "+" button to select "Off." The panel lock is now remove
  • 2 Press the down or up arrows to scroll to the "Setup" option.
  • 3 Press "+."
  • 4 Press the up or down arrows to highlight "Panel Lock."
  • 5 Press the "+" button to select "Off." The panel lock is now remove
  • Read more: How to Remove a Panel Lock on a TV ' eHow.com http://www.ehow.com/how_7581284_remove-panel-lock-tv.html#ixzz3pC8PrE8F
    Feb 04, 2011 | Televison & Video
    Please help, Bush RP40TV
    you may have a convergence ic gone could also be a bad joint on one of the chips or a coil dry jointed
    Jan 14, 2009 | Bush 5693D 24" TV
    Bush 42" rear projection rp40tv sound but no pic
    any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
    Dec 16, 2008 | Bush 5693D 24" TV
    RCA P61927 61" Rear Projection Television Logo
    73 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
